Beoplay H5 Issues
Not Answered This post has 0 verified answers | 9 Replies | 2 Followers
bryce3103
bryce3103 posted on Fri, Oct 7 2016 4:04 PM
I've had these earphones for a couple of weeks now and I really want to like them, but I'm having some problems and wanted to see if anybody is having the same ones. First, the battery seems to be really poor, I wish I could get the even half of the 5 hours quoted by B&O. I use them with the volume at about 85%, and I'm lucky to see 2 hours before the dreaded 50% volume drop. Is there a workaround this? (other than using them at 50% all the time). The second issue I'm having is call quality of the mic, but the problem is for whoever I call, as it picks up a massive amount of background noise. Are these problems for all H5's or am I unlucky and have a dud pair? Thanks for any help guys
jk1002
jk1002 replied on Sun, Oct 9 2016 12:28 AM
To check battery i would let them run entirely dry and see, dropping after 2 hours to 50% could be about right.
Backround noise I havent noticed, but sofar my environments weren't that noisy to be honest.
Duels
England
Duels replied on Sun, Oct 9 2016 8:53 AM
I've got a bit less than 2.5 hours out of mine at about 75% volume before they drop to low battery volume level.
Roy
The Netherlands
Roy replied on Sun, Oct 9 2016 9:10 AM
Hi guys,
To me the H5's are for running/training. As I don't train longer than 2,5 hours it is not a problem to me. I can see the problem when you don't use the H5's for training though. I used the H5's for calling also, but mostly when I'm running in the forest where it is pretty quiet.
Regards,
Roy
BeoVision Horizon ● BeoLab 14 Subwoofer ● B&O Play A9 ● Beolit 15 ● B&O Play H8 ● B&O Play H5
leosgonewild
Helsinki, Finland
Problem solved Big Smile
I use mine for training (1-1,5hours) and the occasional bus ride. Always charge them when I get home, and I have my portable charger in the bag if I need extra juice.
bryce3103
Thanks for your help guys. I ended up taking them to B&O and they said they were faulty and to return them. Hopefully the next pair will be better
Yazes86
Yazes86 replied on Tue, Dec 20 2016 11:51 AM
Hello! Please help me understand. I can not find the multipoint function on headphones Beoplay H5. I want to connect two phones to them.
In addition, I can not find how to update the firmware of headphones. The manual states that this is possible, but I could not find.
Thanks in advance!
mbolo01
Annecy - France
I recently noticed that tone settings are not preserved after a power off, is it the case for other users? I think it is a consequence of the latest firmware upgrade
BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
tommydee
tommydee replied on Fri, Jan 11 2019 12:00 PM
mbolo01:
Recently got my H5s and I have the same issue. Sent a ticket to B&O support, awaiting response. Did you solve your issue? If so, how?
Cheers,
mbolo01
Annecy - France
I opened a ticket (Ticket # 2058381) last July, they ack the issue and said that engineering will have a look at it. No news since .... I sent them a reminder.
In the meantime, I'm setting the tone each time I power it up.
I'll keep you posted in this thread.
Page 1 of 1 (10 items) | RSS
