Are there really no-one that owns a Beocenter 2 anymore ?
Not Answered This post has 0 verified answers | 8 Replies | 0 Followers
Weebyx
Denmark
Weebyx posted on Mon, Sep 26 2016 4:40 PM
Can it really be that no-one are using a Beocenter 2 anymore ? I have a question about the Timer Play function.
Oh, and by the way.. I discovered this morning that it actually is a multiroom system ;)
It is possible to listen to radio or cd in the bedroom while listening to A.AUX in the living room.. Just by adding a Beolink 2000 via masterlink to the BC2..
Totally forgot about that...
/Weebyx
linder
United States
linder replied on Mon, Sep 26 2016 6:48 PM
Weebyx:
/Weebyx
I do own a Beocenter 2 but I am planning on using it in a ML to NL setup when the new TVs are announced later in the year.  Everything you described does work in an ML setup.
Weebyx
Denmark
Weebyx replied on Mon, Sep 26 2016 7:50 PM
Great.... could you please try to add a Play Timer with RADIO as source, and tell me if and where you are asked which radio channel the radio should start playing ?
When I add a timer with RADIO as source, there are nowhere I can input which radio channel I would like to listen to. It just starts on the last channel I listened to..
In the manual it says "when selecting RADIO as source, you should also select the radio channel".. It just never shows on mine..
/Weebyx
parasound
Sweden
Hello!
my Beolab 2000 can play a-aux in the kitchen if
I first start a-aux in my living room or my lounge and push power button
the Beolab 2000.
Everyting else work just fine from the BL2000 (cd/radio/a-mem/tv-sound)
I think this "problem" has to do with the software. Make sure which SW you need for a-aux function on your BL200
Regards//Marcus
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 3-32, DVD1, AV cabinett & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
Weebyx
Denmark
Weebyx replied on Mon, Sep 26 2016 8:35 PM
parasound:
Hello!
the Beolab 2000.
Regards//Marcus
My problem has nothing to do with the BL2000..... The question is only about the timer programming of the Beocenter 2, and why I cannot select the channel the RADIO should start on, when programming the Play Timer...
/Weebyx
parasound
Sweden
Sorry, my fault!
Was reading "is it possible"
altist
altist replied on Mon, Sep 26 2016 9:52 PM
Hi. I will check mine when home on Wednesday evening. I haven't tried the timer yet.
CB
> You are Here <
CB replied on Tue, Sep 27 2016 10:04 AM
Weebyx:
I don't have a BC2, but what happened of you first start the radio you want, then set the timer ?
I think it's the way it works on my BS Ouverture
Weebyx
Denmark
Weebyx replied on Tue, Sep 27 2016 10:34 AM
CB:
Weebyx:
Haven't tried that, but that might be something to test, on all other systems, you specify the radio channel to start on, when programming the timer.
/Weebyx
Page 1 of 1 (9 items) | RSS
