Spotify playlist issues on BeoSound 5
This post has 137 Replies | 10 Followers
Sweden
Posts 352
Martin replied on Sun, Dec 3 2017 6:14 AM
I have bougt an Auralic Aries instead. This cost alot more but I EVER had so good sound in my Beolab5. It is far superior verses all beosound products (Bs5 and Bs9000 with digital feed).
In the latest B&O idea catalogue they recommend Auralic Aries with Beolab 90.
best Regards
martin
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
jhamers
Posts 35
jhamers replied on Tue, Dec 12 2017 4:31 PM
So, they came over and the 'secret' solution is to download the latest version of the spotify for windows app that is supported on XP, sign in and you can control the music through the app on phone, tablet etc...
koning
holland
Posts 4,219
koning replied on Tue, Dec 12 2017 4:42 PM
No wifi dropouts and other issues?
jhamers
Posts 35
jhamers replied on Tue, Dec 12 2017 5:15 PM
My beomaster isn't on wifi. And the way this works is that the app on the beomaster streams music itself, so why would there be drops?
koning
holland
Posts 4,219
koning replied on Tue, Dec 12 2017 5:24 PM
Sorry,i was responding to martin post
IngvarW
Sweden
Posts 38
IngvarW replied on Wed, Dec 13 2017 7:01 AM
Is the installation something you can do by yourself? Do you know if this will be an official installation with support/help on B&O website.
Best Regards, Ingvar
Current; Beosound 2, BV Horizon 48,  2*BL3, BL11, Beolit 12, Beolit 15, Beoplay P6, Beoplay A9, Beoplay H9i
Earlier; BV 10-46, 2*BL3, BM5/BS5, BS9000, BL8000, BV7-32, MX7000, Beoport, Beocord 8000, MX4002, BL2000, Beocom1, Beotalk1200
Beofrank
Posts 79
Beofrank replied on Wed, Dec 13 2017 5:43 PM
Does or does someone have the possibility to create a manual with eventual with screen printing?
beolion
Posts 483
beolion replied on Thu, Dec 14 2017 7:57 AM
jhamers:
I am using this option.
Only downside is that if you select A.AUX to play Spotify connect, then Spotify will continue to play even though you shift source to Radio.
Would have been great if the Spotify App would stop playing automatically if A.AUX is not the source.
Sweden
Posts 352
Martin replied on Fri, Dec 15 2017 4:52 AM
Hi Konig, no dropout and really no other software issue. Auarlic is really fast with new SW when a bug occur.
best Regards
gysse2004
Hellerup
Posts 190
gysse2004 replied on Sat, Dec 16 2017 11:35 AM
Hi Beolion, what version of SpotifyApp are you using on the Beomaster XP ?
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
beolion
Posts 483
beolion replied on Thu, Dec 21 2017 6:42 AM
It is version 0.9.14.13
Pretty old, but it's working :-)
gysse2004
Hellerup
Posts 190
gysse2004 replied on Thu, Dec 21 2017 3:35 PM
Thanks, I have it up and running..
Peter
ethuijs
Posts 65
ethuijs replied on Fri, Jan 12 2018 8:50 PM
What is a safe site for downloading Spotify app version 0.9.14.13? Could not find this download at Spotify site
fixingit
Posts 22
fixingit replied on Mon, Jan 15 2018 4:58 PM
If anybody in this thread is still looking for native Spotify functionality, take a look at this thread:
http://forum.beoworld.org/forums/t/29275.aspx
gerard
Luxembourg
Posts 331
gerard replied on Sat, Mar 10 2018 12:44 AM
@ fixingit
I could not follow your link
fixingit
Posts 22
fixingit replied on Tue, Mar 13 2018 9:24 PM
gerard:
@ fixingit
The moderators took the thread down because adverticing a paid solution is not allowed under the forum rules.
ethuijs
Posts 65
ethuijs replied on Thu, Jan 2 2020 1:01 PM
@SSSUUU with DRmare Spotify Songs Converter  I expect that everytime I add songs to my playlists in Spotify I have to manualy sort this out to convert these to the Beosopund 5. Or is there an easy way to only convert only the new added songs over various playlists?
ethuijs
Posts 65
Page 4 of 4 (138 items) < Previous 1 2 3 4 | RSS
