Beomaster 2200 dead ??
Not Answered This post has 0 verified answers | 9 Replies | 2 Followers
ALF
AUS
Silver Member
ALF posted on Fri, Jul 8 2016 12:38 PM
Hi  everyone,
Again in desperate need of help having taken over a nice looking Beomaster2200.
The BM gets power but no sound - no output ????
Naturally checked all 4 fuses. - all good but where from here ??
Tested tape, phono, am, fm......just silence ?
Is it worth following up or just dump it is another question ? It seems quite challenging taking the BM apart.
Looking forward to read some supporting tips. :-)
Cheers - ALF
Craig
Yarm, United Kingdom
Craig replied on Fri, Jul 8 2016 12:46 PM
Alf
One should never dump B&O.......plenty of people here will provide advice on preliminary checks you can make as a starter for 10
Dillen
Copenhagen / Denmark
Replace capacitors on the power supplier regulator module.
ALF
AUS
Silver Member
ALF replied on Mon, Jul 11 2016 8:51 AM
many thanks Martin,
as usual, you hit the nail on its head  Big Smile
a 4 cap change as suggested brought it back to life.
I left the two 5000uF ones untouched for now as I may change all electrolytic caps
at a later stage - so far it is working nicely !
the only other thing I changed were those wood-trim panel - they are now brushed Aluminium,
which looks much nicer.
cheers
ALF
ALF
AUS
Silver Member
just a brief impression of a wonderful sounding BM - with PSU recapped and balance-slider repaired - thanks Martin !
I wonder if my hearing is deserting me but this BM2200 amp sounds so unbelievably "analog" - way better than my BM1600, 1700 and even 7000 -
no excuses Yes - thumbs up
can you spot the slight modification ??
cheers ALF
marc
netherlands
marc replied on Thu, Dec 29 2016 7:47 AM
I did spot the difference, looks nice!
Lewis T
Hampshire, UK
Hi Martin,
I'm having the same issue with mine have done this, caps on amp boards and the smoothing capacitors and I still have no sound. I was wondering if there is anything else it could be? When you power up you get a power up noise from the speakers.
Kind Regards,
Lewis
Dillen
Dillen replied on Wed, Feb 21 2018 8:25 PM
Did you replace the capacitors on the regulator board?
- And I am not referring to the two large cans held in the metal bracket, I mean the ones ON the underlying board.
Lewis T
Hampshire, UK
Hi Martin,
Yeah I have done the ones on the board underneath and still it's doing nothing, is there anything else I can have a look at to see if that's  causing it.
Kind Regards,
Lewis
Dillen
Dillen replied on Thu, Feb 22 2018 8:21 AM
I seem to remember it has a muting system when switching sound source (to avoid pop sounds), perhaps this is where
the problem is.
Connect a signal generator to the tape input and put a scope to the signal path to see where the signal gets lost.
Page 1 of 1 (10 items) | RSS
