BeoVision 4-50 Table Stand
Answered (Verified) This post has 1 verified answer | 10 Replies | 0 Followers
8000Kristian
8000Kristian posted on Thu, Jun 30 2016 6:01 PM
Last week i did a complete bargain on a wallmounted BeoVision 4-50. But i don't want to mount it on a wall. I have an old B&O F1000 furniture i want to put it on.
And here is my question..
Do anybody here on BeoWorld have a used Table Stand for the BeoVision 4? The two dealers in my town couldn't sell me one. So i should either find a used one, or make one myself.
As i'm living in Denmark, and they are extremely hard to find here, i've prepared myself to make one on my own.
If anybody here have made their own Table Stand for a BeoVision 4, i would be very pleased to see it!
BTW is there a smart solution to upload pictures from an iPad, to the thread?
A young bloke in his early 20's with an expensive hobby..
Present:
Beovision 4-50 Full HD, Beosystem 3, DVD2, Beolab 8000 MK2, Beolab 7-2, Beotime alarmclock, Beosystem 2300, Beolab 2500, Beovision 8-40, Beosound 8, Beo5, Beo4 DTV
Sold:
BeoMaster 7000, BeoVox RL7000, BeoCenter 6-23 DVI, Beolab 4, B&O F1000 furniture, Beovision 8-26
BeoWillie
Calgary, Alberta, Canada
Verified by BeoDunn
Hi Kristian,
I have a BeoVision 4-50 Table Stand for sale. It's in mint condition, sealed in original factory box.
If you're interested, please email me.
beowillie@gmail.com
Regards
BEOVOX141
Denmark, West
Silver Member
The BV4-50 comes in at a whopping 50kg!
Which made me think,- Why not take the base from an old Avant. The center of gravity should be about the same, and the MDF chassis is not only rock solid, but also very easy to modify! The motor assembly is no more than 2 inches high, and would look great as a tabel stand!
I have made several stands from recyled Beovison parts, AV9000 , BV7-32 and the Avant
If you need parts let me know :-)
kallasr
Germany
Try to find out what Panasonic pedestal will fit.
It is a Panasonic Professional display under the B&O frame....
Did so with my Beovision 4-42 (bought a defect Panasonic display with base just to get the stand Big Smile).
Ralf
Living Room: Beosystem 4, Beolab 7-6 (Center), Beolab 8000 (Fronts and Rears) and Beolab 2. Screen: Panasonic TX-P65STW60
Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55
Home Office: Beovision 10-40 on STB Bracket wall mount masterlinked to Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers
Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all White)
Rob - Danish AV
Melbourne
I scrapped a 4-50, it was only the silver frame around the tv and a back frame around the edge too..  The whole back of the TV is how the Panasonic would appear.
8000Kristian
kallasr:
Did so with my Beovision 4-42 (bought a defect Panasonic display with base just to get the stand ).
After some searching i found out that the Plasma panel in my BV4 is a D9, how do i find out which Panasonic displays used the D9 panel? Smile
Present:
Sold:
8000Kristian
BEOVOX141:
I'm thinking about doing that as you suggested. I love the flat disc of the floor stand, so that could very well be the solution if it's going to be a DIY project.
Present:
Sold:
kallasr
Germany
http://www.eurodocument.com/img/data/PANA_S9_UK.pdf
You can install a (second) DVI board as well to have a second HD input (did this with my Beovision 4-42)....
Ralf
8000Kristian
kallasr:
Thank you Ralf! That was extremely helpful. After a bit of searching i found out that the stands were quite expensive, and i'm getting closer to making a stand myself.
Present:
Sold:
8000Kristian
DONE!..Cool
After a small email conversation with BeoVox141, I was ready to make my own table stand and decided to use the stand of an old crt avant.
I found an AV5 2 kilometers from my apartment which I picked up for about 15€. So I took it to my dads garage and started to disassemble it until I had the bare aluminum skeleton. I'm not proud of it, but the rest ended as garbage...Unsure
When I had the bare skeleton I bolted the wall bracket of the BV4-50 to the skeleton, and cut of approximately 10cm of the top.
And voila.. Lets have a Party !!!
I will make a post in the Flash your B&O thread in a couple of days..
And btw. Thanks for your help! Especially BeoVox141
Present:
Sold:
Millemissen
Flensborg, Denmark
Very nice, indeed - applause again.
P.S. You 'could' have made a nice center speaker tor that tv with the AV5 speakers unit, couldn't you?
BeoWillie
Verified by BeoDunn
Hi Kristian,
beowillie@gmail.com
Regards
Page 1 of 1 (11 items) | RSS
