BEOVISION AV 9000
Not Answered This post has 0 verified answers | 6 Replies | 0 Followers
marc
s. wales uk
marc posted on Thu, Jun 2 2016 7:29 PM
Hi to all
i have a AV 9000 TV which is still working well, however its been a sad day because the tv has taken a knock while being moved into another room resulting in contrast screen has smashed, i've managed to remove most of the glass but all four corner glass areas will not remove, seems to be held in place by some sort of  fixing but not sure how to remove with damage.
The other thing i wanted to ask is possible to replace contrast screen if someone maybe had a non working av 9000.
Regards
marc
kai
kai replied on Thu, Jun 2 2016 9:20 PM
Hi Marc
I have an AV 9000 which is in my parents garage your welcome to have it but you would need to collect and I'm in Glasgow if that is any use to you
marc
s. wales uk
marc replied on Thu, Jun 2 2016 9:50 PM
Hi
thanks for getting back to me, thats great news can you PM your contact details etc
Regards
marc
marc
s. wales uk
marc replied on Sun, Jun 5 2016 8:28 PM
I seem to have another problem with av 9000 tv in that i can not get any sound from centre speaker, i have gone through all menus and selected mono to use tv on its own but still no sound, i've tried the built in vcr and a external freeview box but nothing, if i connect a pair of beolab's i get sound but still not form centre speaker also i have gone in to speaker balance setup and have noticed  that there is no setting for centre only stereo L & R.
I have looked at some of the older posts on this forum and lot mention about error codes but no error codes on my tv all working fine apart from what's mentioned above.
Please could someone shed some light on this problem.
Also would like to Thank Kai for his kind offer which i will take him up on.
Regards
kai
kai replied on Sun, Jun 5 2016 11:24 PM
Marc just seems your problem about centre spk, make sure the comer toon is in the correct socket, to test the speaker if you have beo4 press list till speaker appears then press 1 that should bring the sound through the centre speaker
marc
s. wales uk
marc replied on Tue, Jun 7 2016 7:24 PM
Hi Kai
what's comer toon, anyhow i will try the test with the beo4 when i get back this weekend, thanks for input
Regards
marc
marc
s. wales uk
marc replied on Sun, Jun 12 2016 4:33 PM
Hi
OK i tried what you said with beo4 remote, speaker 1 comes up on screen but still no sound, i've also checked all wires from speaker to main board and all connected ok
Marc
Page 1 of 1 (7 items) | RSS
