Cleaning/labelling the Essence Remote
Not Answered This post has 0 verified answers | 15 Replies | 2 Followers
Chris Hassell
London
Chris Hassell posted on Thu, Apr 14 2016 9:06 PM
Does anyone have any experience with cleaning under the round plastic cover on the front? I have slight liquid marks that have crept under the edges after an orange juice was spilt on it (OH I LOVE MY 3YR OLD DAUGHTER SO MUCH Stick out tongue).
Probably a similar task: has anyone tried replacing the labelling underneath this plastic disc (if that's what it is). Could make it even more handy as a home automation room remote??
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
leosgonewild
Helsinki, Finland
Silver Member
I got a dent in the wheel, and I tried to remove the wheel. Seems impossible to disasemble the unit :(
Chris Hassell
London
Lesson: if your kid spills a drink on you essence remote and there's a little bit of liquid left under the front plastic for 4 months that annoys you everytime you see the (still functional) unit. Don't use a hair dryer too long on it to finally get rid. It ends up with the plastic warping and the 'label layer' part under the plastic wrinkling up a bit.
Whoops! Embarrassed
Made me wonder if it is possible to take the front off though and replace the 'label layer' with bespoke labels.
Oh and also - I replaced it with the wall version with the Bang & Olufsen logo in the middle (by mistake I'm getting the metal tabletop stand back). This is a new model with the IR+BT modes on. I remember reading somewhere on here that people thought they didn't make the wall version anymore. Seems they do. If anyone is interested!
TWG
TWG replied on Tue, Jun 14 2016 8:34 AM
Is there a new updated mode sheet showing which LED combination is active when IR and Bluetooth can be used simultanously?
Does anybody know for sure since when the new versions are made?
Is there a service manual available to dissamble them without destroying them?
Chris Hassell
London
TWG:
Is there a new updated mode sheet showing which LED combination is active when IR and Bluetooth can be used simultanously? Does anybody know for sure since when the new versions are made? Is there a service manual available to dissamble them without destroying them?
The modes are all outlined here @TWG :
http://forum.beoworld.org/forums/p/17876/156154.aspx
Millemissen
Flensborg, Denmark
In the B&O FAQ's they still only list the 7 modes.
Maybe these new 'combo-modes' will be described, when the new BROne/BT will be launched.
There might be some new possibilities then - maybe even with the new BV/BV's.
Just speculating - my dealer couldn't say much about this :-(
AnalogPlanet
Vienna, Austria
Hmm, and now I have some liquid marks behind the plastic mask of the wheel. Anyone figured out how to remove or clean it in the meantime? Big Smile
beowild
Silver Member
beowild replied on Sun, Nov 29 2020 11:14 AM
Hi, Our essence remote has no visible liquid marks behind the plastic mask of the wheel but some functional problems due to a splash of red wine: Although we instantly dried the battery housing and the lower compartiment of our table remote (advice from beoworld for a submerged beocom6000) the "forward" button on the wheel doesn't work anymore. All the other functions work perfectly.
Anyone out there who tried to disassemble and clean the whole thing?
Thanks in advance
David
laseralex
There is a little information here:  https://forum.beoworld.org/forums/t/36696.aspx
This part seems particularly relevant:
leosgonewild:
I remember someone had spilled some drink on the remote, causing some discoloration under the plastic plate with the logo. At least that can be easily removed with a spider to be cleaned.
It is made of plastic, and glue holds it in place.
However, if the switch itself is damaged it is probably not possible to repair due to the assembly techniques: the remote was rally designed to be assembled once and never disassembled..
If you are in the US I'd be willing to take a look at it - I'm a self-employed Electrical Engineer with a full design lab, which means I alsohave equipment for rework/repair.  Unfortunately I'd give the likelihood of being able to actually repair the switch at no more than 20%, but I absolutely love the Essence remotes (see my signature, LOL) and I would be willing to give it a try for you.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x Essence Remote  • 1x Beoremote Halo
BenSA
Durban, South Africa
BenSA replied on Tue, Dec 1 2020 7:22 AM
I have an issue with my essence remote that when I turn the wheel nothing happens then all of a sudden the volume goes really loud. It does go up or down in volume gradually
laseralex
BenSA:
Unfortunately I've noticed that a remote which hasn't been used in a while will drop the connection of the device it is controlling.  This is undoubtedly done to improve the battery life, but results in the issue you mention.  Of course the remotes I have controlling my two Beosound Moments don't have this issue, as they're set in IR mode and don't have an understanding/"memory" of the target volume.
If I try to change volume and don't get an immediate response, I've learned to wiggle the knob back and forth until I get control, then turn up to the target volume.  If a couple of seconds of wiggling doesn't give me control, pressing the top button of the remote usually makes the connection happen.
The essence remote isn't perfect, but it is a beautiful and incredibly useful product.  I have been debating designing and building a "next-generation" knock-off with an E-Paper or OLED display in the center, to add the Halo's track/station display to the otherwise perfect Essence Remote.  As an electronic designer I know how to do this, but I suck at marketing and would struggle to sell enough to recoup my time investment.  (Lyle Clarke, if you're reading this please put me in touch with whoever hires your external designers, and let's make this a B&O product.  LOL.)
BenSA
BenSA replied on Tue, Dec 1 2020 8:38 AM
laseralex:
BenSA:
I have noticed that if I wiggle it first then its better. I have mine in IR mode as well so not sure why its still doing that. Its a bit annoying I have to say but it is very pretty so leave it on the coffee table. I mostly use a Beo 5 instead.
trackbeo
ONLINE
laseralex:
Formidable!  (In both the French sense and the English, heh.)  If you haven't already, check out the Senic Nuimo (https://www.senic.com/nuimo-control ; unavailable but possibly because https://www.sonos.com/en-us/shop/senic-nuimo-control-starter-kit.html ).  There's also an interview showing their handwork factory: https://darko.audio/2019/06/onsight-an-afternoon-at-berlins-senic/ .  I find that, aside from wake/sleep, Nuimo's UI flaw is its short range to the base -- thus feedback is a problem and any "prospective" displays based upon expected results are often "wishful thinking."  Maybe surrounding the Bluetooth antenna with all that mechanism is the cause?  Likewise people complained more about the Griffin PowerMate Bluetooth than the wired PowerMate, also worth a teardown if you proceed.
Re: waking the wheelie, someone here suggested always turning the control *down* with a couple/few click-at-a-time rather than wiggling it, to avoid a potential sync on the upswing and thus blasting the room.
laseralex
trackbeo:
I had seen it before but didn't spend much time looking at it.  I find it interesting that if won a reddot design award in 2016, just 2 years after B&O got a reddot award for the Essence Remote.  The Nuimo looks like a knockoff of the Essence Remote, and I find it far less attractive, so it surprised me to see the knockoff award the same design award as the original just two years later.
Millemissen
Flensborg, Denmark
As seen on the Senic website it is ‘sold out’.....whatever that means?
Probably they are more active selling rhe Senic Click nowadays.
Page 1 of 2 (16 items) 1 2 Next > | RSS
