Beogram CDX
Answered (Not Verified) This post has 0 verified answers | 17 Replies | 3 Followers
Lewis T
Hampshire, UK
Lewis T posted on Mon, Jul 16 2012 12:52 PM
Hi, I have recently brought a beogram cdx cd player its mint condition and has been working fine until a few weeks ago. When you load a disc it don't spin up, you load the disc and it moves like a centimeter and stops and on the screen it displays somthing like a question mark. However some times you put a disc in and it works with no problem straight away. its really starting to annoy now Ive tried everything different amps, different cds even a laser cleaning disc but doubt that would do anything because the way the laser shines though the little rising platter thing.
Any help or idea would be appreciated
Lewis
j0hnbarker
Could it be something as simple as you not loading the CD correctly? If you get the CD to slip down in the holder then you will get the same symptoms of the question mark that you are describing. One of the quirks of the CDX is the loading tray and its ability to sometimes let go of a CD. As you can get it to work sometimes then I have a suspicion that if you double check the CD is sited properly each time the problem will be solved.
Lewis T
Hampshire, UK
Hi, Thanks for your message I have had a go with what you suggested and its still the same now its trying to spin like 1 whole turn of the disc then it stops with the ? sign on the screen. Not quite sure whats going on could it be possible the lock in screws have something to do with the problem ?
Thanks,
Lewis
Steffen
Denmark
The way you describe it, it is probably some electronics problem. Those models had some issues with bad solderings. Or maybe it's some worn out components. It IS rather old - so no wonder if some components need to be replaced.
Hardwriter
Sorry to have to tell you those are the symptoms of the classic soldered joint problems but they can also indicate bigger troubles. My CDX had soldered joints repaired which fixed this problem but when it emerged again the service engineer said it needed a new laser board. It was pretty old by then and he said parts were not easy to locate so I sold it to him for spares and bought a Beocenter.
Probably worth dropping it in to a B&O engineer just in case its the soldering problem but I think most will have already had this fixed.
Peter
Earsdon
Peter replied on Fri, Jul 20 2012 2:42 PM
The lasers are bullet proof - the solder joints anything but! Common problem and fixable - worth it as well as this is a very sweet CD player - I compared it with some £1000 new ones a couple of years ago and preferred the CDX.
Peter
hamacbleu
Québec, Canada
I acquired a month ago a beogram cd x that was only powering up: only a question mark, no spinning at all of the cd... Dillen, on this forum, gave me a good direction to look at... then I found a schematic somewhere that Peter gave on a earlier post... I also found this french page on the philip cd 104 (the problems, and pcbs are identical to the cd x..)
http://www.audiovintage.fr/?p=894
and here's the old post:
http://archivedforum.beoworld.org/forums/p/28100/220727.aspx
Today I bought a soldering Iron, I've studied carefully for weeks the service manual... I NEVER touched a soldering iron before....
This image is taken from the said french site. It's the servo PCB (no 4) of the philip 104: I only desoldered and resoldered (with a wire passing through the pcb) the two griplets shown with a red arrow. I reassembled all the machine (I did not want to touch to the griplets on the other pcbs... I was sure that, anyways, that would't work and I didn't want to break anything since i'm not experienced at all in soldering...Guess what??? that CD player is like new! I've enjoyed the sound of it all the evening!  I can't see any problem with that machine whatsoever...and it what made in 1986! (Ok I was disapointed since I thought that my machine was trimmed with rosewood... I just found out that it was only a vulgar plastic laminate imitating the said wood (I wonder when B&O stopped doing their real wood trimming...)
Anyway it's worth repairing.. If I can do it, anybody can do it... thanks to Peter, Dillen and Kikook! (Now I'll have to tackle that beomaster 8000)
hamacbleu
Québec, Canada
Suggested by Jason
... I also suggest that article by Mike Leach about the philip cd 104 found on tvcaudio. It's a good complement to the beogram cdx...
http://tvcaudio.com/tvc/Philips/documentation/servicing%20the%20Philips%20CD104%20CD%20Player.pdf
chartz
Burgundy, France
chartz replied on Sat, Aug 18 2012 7:55 AM
Great job Lewis!
Exactly what my own CDX needed too, almost three years ago!  It's been working fine ever since.
Now that you've done that you will irresistibly feel like buying and fixing other B&O stuff... Beware, there is no turning back! Big Smile
Jacques
Steffen
Denmark
hamacbleu:
Are you talking about the CD X? Wood trim??? I've never seen that on a CD X Huh?
Could you post a picture of your CD X ?
hamacbleu
Québec, Canada
Simili "rosewood" plastic trim. This could peeled off like scotch tape. This is when the eighties went cheap. Altough it does fit with the rest of my equipment...
Dillen
Copenhagen / Denmark
Dillen replied on Mon, Aug 20 2012 6:39 AM
That "wood trim" is not original.
Stuck on by a previous owner, I should think.
Well done on the repair.
smokinglegges
Hello Hamacbleu,
Thank you so much for the tips on repairing my Beogram CDX I've own since '86. It stop working in around '98 and haven't used since now. I used my soldering iron on all the griplets with a little silver solder and I couldn't believe it. Thanks so much.
Gary Legge
hamacbleu
Québec, Canada
smokinglegges:
Hello Hamacbleu,
Gary Legge
Hi Gary,
Congrats on your repair. And thanks bringing me back those nice memories of my 1st successful B&O repair. Mine still plays flawlessly after 4 years, thanks to the resources and supportive people of this forum. The CDX is the most beautiful CD player ever. Hope yours will also bring you years of nice music.
Guillaume
chartz
Burgundy, France
chartz replied on Sat, Sep 30 2017 2:19 PM
There's a nice article by Tim about the CDX in the November issue of Hifi News & RR. Enjoy!
Jacques
Page 1 of 2 (18 items) 1 2 Next > | RSS
