How do you check on what version of Beo4 you have ?
Not Answered This post has 0 verified answers | 20 Replies | 1 Follower
elephant
AU
elephant posted on Wed, Jul 11 2012 6:54 PM
I thought my Beo4s were equal - now I am struggling to find [DTV2] on one of them.
  1. Is there a Beo4 service command string that reveals the Beo4's software level etc ?
  2. Alternatively, is there a hidden key sequence that magically adds [DTV2] to the list ?
(and yes, I know DTV2 seems some how to map to VAUX but I am chasing the answers to 1, or 2, or both Smile)
Thanks.
BeoNut since '75
Paul W
London
Paul W replied on Wed, Jul 11 2012 7:03 PM
Strangely, my first Beo4 from 1999 is a far nicer metal material than my 2005 BV6 and all of the latest ones. I wonder why they changed the material used?
tournedos
Finland
  1. GO+MENU at the same time; then LIST through the displays.
  2. No. I think it's there starting from SW 6.22.
--mika
Chris Townsend
Badsey, UK
personaltrainerpaul:
Of all my gear, the Beo 4 is the one piece I don't consider there is a better device to be had. And i already own a Beo 6(which sits in it's cradle waiting to fall over and break)
Beovision Eclipse, BeoLab 17,Beolit 15, Beoplay A2 Active
elephant
AU
elephant replied on Wed, Jul 11 2012 10:00 PM
tournedos:
Thanks !
  1. Did that and it worked showing EE 6,1 and SW 5,0 on both units
  2. SW 6.2 ?
    Now I am confused Smile
    Is EE and SW combined the indication of level ?
    Or if it is SW only and your SW 6,22 is correct, how did [DTV2] get on to only one of them ?
BeoNut since '75
Paul W
London
Paul W replied on Wed, Jul 11 2012 11:46 PM
I agree Chris, the Beo4 is the world's best remote control!!! Just perfect in every way! The Beo5/6 truly sucks!  Beo4 simply incredible, iconic and does what it says on the tin!
Vienna
make an educated guess
Vienna replied on Thu, Jul 12 2012 1:34 AM
elephant:
  2. SW 6.2 ?
Very likely they have a different "Video-Config"
= Set of names for the same IR commands that fit to different (older/newer) TVs.
STDBY + LIST > >> LIST till CONFIG? > GO > VIDEO? > GO > LIST till VIDEO 4 is displayed > GO
Verified on my oldest Beo4 displaying EE:6.2 / SW:5.0 / VIDEO4 / AUDIO 1
"LIST" is offering both  - "V.AUX" as well as "DTV2"
Steffen
Denmark
Paul W:
Have they changed the materials on the Beo4? Huh?
I have had all of the Beo4's, except the latest version. I must say that I haven't noticed any changes in the materials...
Unfortunately I no longer have the Mk 1 to do a comparison...but the 3 Beo4's I have now looks and feels quite alike (except from the buttons, offcourse).
Jonathan
Melbourne, Australia
Steffen:
Paul W:
I have them all (Mark 1,2,3 and 4) and they're all made from the same materials.....
x:________________________
elephant
AU
Jonathan:
Steffen:
Paul W:
We handled the new (joystick) Beo4 last weekend at the dealer in Collins Street - to me the underneath has a new texture and feel to it - perhaps it will age over time, but it felt quite different; and Sue said she thought it felt lighter than ours at home
BeoNut since '75
Mindphaser
Chris Townsend:
Cannot quote enough.
For me; especially for materials used and for 'look and feel', BEO4 is the best remote command ever made.
I tried a BeO5 from a friend of mine;but it seemed to me way 'cheaper' than BEO4; i mean it looked like a gadget ...you would thought that BeO5 could be make in China or whatever, BEO4 is so firm and  solid that you would NEVER thought that Smile
elephant
AU
Vienna:
elephant:
  2. SW 6.2 ?
Thanks Vienna - your advice and details are always so accurate.
My two Beo 4s are:
  • VIDEO 1
  • AUDIO 1
  • EE 6.1
  • SW 5.0
However there is a distinct difference when I step through ADD? LIST LIST LIST comparing their "features"
The one which has DTV2 also has P-DTV2, L-DTV2 et cetera; and of course VAUX.
The other one has NO DTV2s at all.
As you can expect, looking at two Beo4s and pressing
  1. LIST, LIST compare
  2. LIST, LIST compare
  3. LIST, LIST compare
  4. LIST, LIST compare
  5. et cetera
is very time consuming, boring, and incredibly irritating when the two lists get out of order because at different times they have had different things ADDed, REMOVEd and MOVEd !
But I will eventually find what is added and/or replaced and/or missing .......... even though it is largely an academic exercise !
BeoNut since '75
Vienna
Vienna replied on Thu, Jul 12 2012 10:12 AM
elephant:
Just a guess, maybe the other Beo4 has previously been in an other video-config than "video1" and is
therefore still "remembering" the set of DTV2 commands ...
Big Smile ...  on the Beo 4 w/o "DTV2" try a change of the config for  video to a different version ( video 2 / 3 / 4)
and check if "DTV2"  appears in the "LIST" ...
elephant
AU
elephant replied on Thu, Jul 12 2012 11:15 AM
Vienna:
elephant:
Yes, I had a similar thought - so I took your advice ... first observation is that doing this wipes the pervious settings !  Secondly since you mentioned you had VIDEO = 4 I tried that first ....
  • VIDEO = 4 ... no DTV2
  • VIDEO = 3 ... no DTV2
  • VIDEO = 2 ... no DTV2
hmmm, what do this different video options do ?
BeoNut since '75
Vienna
Vienna replied on Thu, Jul 12 2012 1:10 PM
elephant:
... hmmm, what do this different video options do ?
"History" compatibility =  Change of "displayed name" in the "LIST" for the same IR commands
(to better fit to different older/newer TVs).
Adding / removing "special commands" needed only for some types of TVs
PS:  My Beo4 is EE:6.2  - that may explain the difference
        but you say, both of your Beo4s are EE 6.1 and only one has DTV2 ! - I'm also Confused
Page 1 of 2 (21 items) 1 2 Next > | RSS
