Beogram 1800 type 5213 the rare one , slow motor
beo3000
Posts 104
beo3000 Posted: Thu, Feb 11 2016 2:41 PM
I have got a beogram 1800 that seems to work correctly but has very slow motor so I have started to dismantle the motor
has anyone else had any luck fixing these motors I think it is the same one from the beogram 1000 its seems a lot more difficult to fix than the 1202 motors, there doesn't seem to be a screw to release the capstan
also, the tarnish on the aluminium is there any way to get that off,
manny thanks
beo3000
Posts 104
beo3000 replied on Thu, Feb 11 2016 2:43 PM
also does anyone know how to add more than one image it seems every time I try and add another images it overwrites the last one
beo3000
Posts 104
Ben_S
UK
Posts 615
Silver Member
Ben_S replied on Fri, Feb 12 2016 8:13 AM
Nice deck,
Can't help on the motor point but I know that the metal trim does tarnish with age and almost every 1800 I have seen has this problem. I don't think there is a solution.
Ben
Page 1 of 1 (4 items) | RSS
