Beolab 5000 renovation
Not Answered This post has 0 verified answers | 25 Replies | 0 Followers
Christian Christensen
Stockholm
Silver Member
Christian Christensen posted on Tue, Feb 2 2016 9:39 PM
Sooooooo I finally got myself a Beolab 5000 , and it is perfect visual shape, yeeeah
Begun renovation, could see that atleast half of the caps were bulging, so I took the decision of total recap, to begin with.
Endless work...sooooo many caps in it.
Have decided to order new windows from Dillen, to start with.
Anyone that have tips for this renovation ?
My re-capped M75 are my precious diamonds.
Stockholm
Silver Member
Image was half way through recapp.
I have used my choices of caps. not axiell caps but radiels because thats what I had at home.
The 470 uF have  I increased to 1000 uF as they are pure smoothings.
The only reason they were choosen 470 at the time was limitation of size.
There are a few caps here and there that I have increased value due to  electronic design.
Stockholm
Silver Member
And have made my decision not to do as deep renovations you did Sören.
my BL5000 is in excellent shape.
I am awaiting some more caps and after that I will slow start it with 30% on the variac and measure idle current. If that goes well it is ready
I am not so sure that transistors needs to be replaced, if they work the work.
IIf I take decision to replace the 6002  I will use equalient BC549 and 559 as they are low noise transistors.
I have checked out the spec and they should go well
Søren Mexico
Mexico City
In after thought I would go for radials caps instead of the standing axials easier to get equivalent sizes, as for the black drop TRs Frede recommended me to change them with BC 550/560C but BC549/559 are indeed very close. Frede has found out that these TRs gives intermittent failures (distortion) at times.
Compared to mine yours look very clean, how are the fronts ?
Dillen
Copenhagen / Denmark
Christian Christensen:
May I ask, on what do you base that statement?
And you are not using WD40 anywhere in a B&O - are you ?
Stockholm
Silver Member
Yes you may dear Dillen.
It is obvious that it is very tight in the Beloab. Smile
I cant see  how a 1000 uF would fit inside there.
Even though the stabilizing circuits , dont you think they would have crammed in a 1000 uF if it would be possible ? Smile
WD 40 ?Big Smile ohh no, The reason it is on my kitcchen table is that before I got to the BL5000 I was dealing with a tricky mechanical problem inside of a Pioneer turntable from the 70ths  ;)
Christian
Dillen
So if you stick to that theory and method of restoration, you will "upgrade" all caps to the maximum possible value you can
physically fit, safely assuming that's what B&O did?
The engineers at B&O wouldn't design something to work best with 1000uF and then accept to only fit
400uF because "There wasn't room for more".
Not anywhere.  - Let alone in a top-range amplifier like this.
WD40 not in a B&O but in a Pioneer, that makes sense...
Dillen
The original 400uF was already well dimensioned - as the far majority of components in there are.
That's also why these beasts work well and live long.
It's your restoration and you can mount what makes you feel happy, but don't blindly up capacitor values in the
name of improvement and do keep in mind, that something happens to f.e. the rush-in current when you up the
filter capacitor (- and particularly if you fit a low-ESR type capacitor, which seems to be an often misunderstood method of "upgrading").
The increased load and stress on the rectifier diodes, the voltage regulators and the surge-limiting resistors may
or may not result in problems sooner or later. I recommend you don't just up capacitors without a good reason.
Dillen
- And if you replace the rectifier diodes with Schottky types, I will be writing again! :-)
Stockholm
Silver Member
Not that I had any idea of replacing the rectifier....Hmm is is selen recitifer in it ? Erm..
Stockholm
Silver Member
Ahhhh now I understand what you were trying to say ;), got confused for a bit. :)
Stockholm
Silver Member
This thread will go in pause for  a week or two.
Have so many other units for other people that come in for repair.
It started with showing my own B&O repair/refurb on a vintage hifi  forum.
Since I started this hobby 3 years ago I have had about 20-30  repairs of other brands. :)
Nikko, Sansui, Technics, Tandberg aso. I have very little time for my own beloved B&O stuff nowdays....  Wink
Page 2 of 2 (26 items) < Previous 1 2 | RSS
