BeoCom 2 - connector pinout
Not Answered This post has 0 verified answers | 1 Reply | 0 Followers
kammeri
kammeri posted on Mon, Dec 7 2015 2:28 PM
Gentlemen,
I am lacking the original power supply of a BeoCom 2 combined base station. Does anyone have information regarding the pinouts of the BeoCom 2 base station cable (Mk 1)?
There are two connectors on the cable. One RJ45 which has four wires connected, two on each side of the RJ45. I assume these are the ones that connect to the power supply. But why are there four wires and what is the function of each wire? The other connector is a standard RJ11 with only two wires so I assume it has nothing to do with powering up the base station, as is the case with BeoCom 4 and 6000.
Regards!
booja01615
Hey! Thanks for the information!
I wanna show you payforessay.net website that helps in my difficult education. Customized case studies are now simply to do thanks to one helpful website. You will be able to get high marks in all your subjects and you will be very happy with the result. You can try to order now as it has the lowest prices.
Page 1 of 1 (2 items) | RSS
