Is it possible to upload current config on my Beo5 to new laptop?
This post has 4 Replies | 2 Followers
Chris Harrison
Peak District
Posts 379
Chris Harrison Posted: Tue, Jun 26 2012 10:18 PM
Is it possible to upload current config on my Beo5 to new laptop? Any ideas how?
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Keith Saunders
Little Ann, Hampshire, United Kingdom
Posts 5,164
You CANNOT download from your Beo5 to the Configuration Tool.
If someone else produced your configuration and uploaded it to your Beo5, then you will need to get a copy of that configuration file, otherwise you will be forced to recreate the configuration from scratch.
Regards Keith....
Keith Saunders
Posts 5,164
If, however you produced the configuration on another PC and you now have a new PC, then you can transfer the "Configuration.xml" from the clients sub-directory to the same location on your new PC
Regards Keith....
BeoHut
Posts 475
BeoHut replied on Wed, Jun 27 2012 7:56 PM
This is correct Keith.
I use many laptops and the only thing I have to do is copy the configuration.xml-file.
This has always worked for me
Put on your new/other pc the file in the correct directory, otherwise it won't work and you have to start from the beginning.
Chris Harrison
Peak District
Posts 379
In which folder does the config file have to go?
Page 1 of 1 (5 items) | RSS
