CDX no sound -griplets?
Answered (Not Verified) This post has 0 verified answers | 17 Replies | 2 Followers
Garten
Sweden
Garten posted on Sun, Nov 15 2015 8:18 PM
Hi all,
Had my CDX suddenly stop outputting sound, everything is normal as before, spinning, lid, changing tracks...all is fine... just no goddam sound...
Did the regular forum searches and seems the via's (griplets) are the usual suspects for motor/spining problems,.. but as the servo pcb isn't involved in sound output, could it be as easy as griplest on the decoder board?
I read that there was a muting relay that could also be problematic? (like the beocenter 9500?) could I diagnose that in any non destructive way?
I know I can just open it up and sort the via's as a first measure...but i'd like to get some advice on alternate diagnosis before i heat up the ol' iron. ....decoder PCB caps?..or would they cause bad sound.,, and not my situation, which is NO sound whatsoever...
many thanks
/g
BM 2000 *1974, 2x BM 1200, BM 1001, BG 1200, BG CD X, BC9500,BM3300,Bcord 3300, BG CD3300, Beovox Cona, Beovox CX100, Beovox 1200, Beovox RL60.2
Lee
Newcastle upon Tyne UK
Lee replied on Sun, Nov 15 2015 9:27 PM
This post seems to have a few suggestions. The muting relay could well be the issue.
http://archivedforum.beoworld.org/forums/t/39355.aspx
chartz
Burgundy, France
chartz replied on Sun, Nov 15 2015 9:44 PM
Yes, the muting reed relay itself or its solder joints is the first thing to check.
Not doing the vias is calling for trouble anyway, so do that too to avoid future problems.
Jacques
Garten
Sweden
Garten replied on Sat, Nov 21 2015 3:13 PM
Worked on the said griplets with wire and iron on the decoder PCB only, BAM! sound again!!
Couldn't find the reed relay...but as further analysis wasn't needed I will now sit back and enjoy with my 1974 Beomaster 2000, match made in heaven!
Many thanks you all!, here are some pics!
Garten
Sweden
Garten replied on Sat, Nov 21 2015 3:14 PM
smokinglegges
I had this exact same problem and shelved my CDX for years until I read this. Did the same, just heated up the giblets. Then no sound on one channel. I had crimped the output wire in putting it back together. Re and re and it sounds incredible. Thank you so much for this post, I am one happy guy. Still use the same system I purchased in 1985.
Beonix
Carmarthen UK
Silver Member
Answered (Not Verified) Beonix replied on Fri, Jan 18 2019 2:55 PM
Suggested by Beonix
Hi All... I realise that this is an older thread, but I have just been working on a CDX with exactly the same symptom of no sound output, but everything else working...
Having resoldered all griplets on the decoder PCB, still no sound...
Turned out to be faulty reed switches (contained within the 'kill' / 'muting' relay)...
I will replace with Farnell type 240-9213 glass reed switches...
Tony
Brian Laing
Walnut Creek, CA USA
Did that work for resolving your “no audio” issue? I’m having the exact same problem. How difficult was it to replace them yourself?
Beonix
Carmarthen UK
Silver Member
Beonix replied on Sun, Oct 13 2019 8:32 PM
to be absolutely honest, I simply bridged the relay contacts on the muting relays...
brianlaing
Walnut Creek, CA, USA
Then you didn't replace the reed switches? Is there any effect from the relay contacts being bridged?
Would you still recommend Farnell type 240-9213 glass reed switches if I were to do that?
Dillen
Copenhagen / Denmark
ONLINE
Dillen replied on Sat, Oct 19 2019 7:43 AM
The relays are there to prevent noise in standby.
In some decks they are also used to prevent "unpredictable audio signals" going to the amplifier while reading TOC etc.
Why bodge it like that? - Why not just do a proper repair and replace the reed elements?
chartz
Burgundy, France
chartz replied on Sat, Oct 19 2019 9:51 AM
I agree with Martin.
Reed relays are dirt cheap and a doddle to replace. The other relays are for CDs that have treble boost (pre-emphasis).
In Spotify, for instance, they can't be bothered about that and those CDs are incorrectly ripped, which makes them very bright.
Jacques
RafH
Silver Member
RafH replied on Tue, Jun 23 2020 10:38 PM
Hello ,
Sorry for being a pain and refresh the post( I have same issue with my CDX)  Where can I locate mute relay?
Thank you.
RafH
Silver Member
Hello ,
Thank you.
Dillen
ONLINE
Dillen replied on Wed, Jun 24 2020 6:38 AM
Rearmost on the decoder board.
Page 1 of 2 (18 items) 1 2 Next > | RSS
