Change light bulb on a Beosound 3000 ???
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
cfap
cfap posted on Sat, Oct 31 2015 8:05 PM
Good evening,
If anyone could help me to know how replace light bulb on a Beosound 3000 ?
I don't find the process on websites and prefer not to try it on a wrong way,,
Thank's a lot for your kindly help.
Best regards
marexy
marexy replied on Mon, Nov 2 2015 12:16 PM
you must teke the front plate of the unit.
1- detach glass doors
2- detach black plastic behind glass doors
3. udse torx to un screw  and detach the front plate.
and than you can change it.
easy .. :)
Beobuddy
Utrecht, The Netherlands
Mind the screw at the back for the loading mechanism.
marexy
yes and no...
you can only detach a metal rod from the front if you partly detach fron plate before that.
but it is easier if you take your rear cover of.
Page 1 of 1 (4 items) | RSS
