Using non B&O cartridge in B&O Turntables
Not Answered This post has 0 verified answers | 25 Replies | 2 Followers
marcocx
marcocx posted on Sat, Oct 31 2015 11:52 AM
Hi everyone,
I've had a chance to listen to a few B&O Beogram turntables, and been wondering if there is any way to use a non B&O cartridge with them? I know B&O uses their own mounting system, are there any adapters or anything available to plug in say a Ortofom 2M Red cartridge?
Regards
Marcocx
Adrian2b4u
Rebuilt -cant cartridge an stylus are completly missing.
MMC4 - can you PM me a link ?
TY.
Dillen
Copenhagen / Denmark
Dillen replied on Thu, Sep 26 2019 12:13 PM
Adrian2b4u:
TY.
Email sent.
Pctrend
Welcome to the forum. I'm trying to fix it my
Beogram 5500 and change B&O cartridge. Will this cartridge be good?
Ortofon Concorde Mix MKll for rebuild.
Great idea Mr ProGram  congratulation Smile
ProGram
59269 Beckum, Germany
the DJ Concordes may be ok but not advisable. They have spherical tip and a tracking force of 3g. But the body will do its job and the needles are interchangeable. So you can use a better one like theOrtofon stylus 20 or 30
Layesera
I have just adapted my Beogram 1102 arm to accept any OM stylus. A tricky little job but with a little patience it all worked out fine.
ProGram
Would be nice to see it mounted to a deck.
This is how my trial with a radial tonearm looks like:
chartz
Burgundy, France
chartz replied on Mon, Dec 21 2020 9:35 AM
Alignment is probably off. The sound will be highly distorted as a result.
Jacques
Layesera
Surely if you buy a Soundsmith you are still not using an original, so what's the difference. I have one Bang & Olufsen with a Ortofon OM modification and it works fine.
Layesera
I have just sent  off my MMC2 for my Beogram 7000 to be repaired and we will see how it goes. If unsuccesful I will do a modification. I have done a Beogram 1102 Ortofon OM Modification. It was just a prototype on a pretty tatty deck but it worked out fine. Nothing can be sustained forever.
Andrew
Frinton, UK
Andrew replied on Thu, Jul 22 2021 7:37 PM
I wouldn't bother - you risk damaging the tone arm and this will reduce the value of the turntable. You can get decent second hand retipped cartridge's on ebay - I bought one for my 4002 until I can afford to get a really decent one. That cost me £150 and works really well and I can keep it later as a spare.
The other problem as others have mentioned will be the alignment, the arm mass maybe unsuitable and depending on the Beogram you may not get enough tracking force. There is over hang to consider and all sorts of other techie stuff which is why a Beogram is so appealing - you have none of that to consider just press play and away it goes. No alignment issues or setting up of the cartridge either - just plug it in, set the tracking weight and away you go.
On sound quality my BG4002 sounds just as good as the Linn LP12 I was previously using which has a rega tonearm and £300 rega cartridge - which by the way cannot have its stylus changed either. My Beogram 3000 from the late 60s even sounds fantastic with a second hand SP12 and I'm using them with a decent front end and speakers that are quite revealing.
I think my only other comment would be that it would bug me that the turntable is not as it was intended - I think its fine to change some components internally in old equipment so that it is brought up to date, but with turntables where the cartridge is on display and part of the design I think it should be left alone. But these are only my comments and at the end of the day it is your property and upto what you do with it.
If it were me I would just wait and put any money you would spend on modifying the turntable towards a B&O Cartridge.
Layesera
I am at the moment waiting for my MMC4 for my Beogram 7000 to be returned afer repair. It cost me €300 to have it done.
I do think th B & O's are a great design but I am 73 years old and have had many, many turntables in my time. Bang & Olufsen are not in the running for some of the turntables I have had. This 7000 in no way as good sounding as my Revox B790 linear deck or even my Mitsubishi LT20 linear deck, and definatley no where near my Mission 775s belt drive or my Victor QL-10 with UA-7045 tonearm with Ortofon Red fitted.
It all boils down to personal taste and when my cartridge arrives, the whole 7000 system will be complete, all original and working.
I am sure I will be very happy with it,  but having had better systems and still have better sounding gear we will see how long it get's used as my main system.
Page 2 of 2 (26 items) < Previous 1 2 | RSS
