BS3200 Hard Drive
Answered (Not Verified) This post has 0 verified answers | 2 Replies | 1 Follower
mfirst
mfirst posted on Mon, Oct 19 2015 2:08 AM
I know this might be an old topic - but I have been using my BS3200 more and more and worry about the hard drive failing....granted it is old technology - which is concerning as I am afraid that if (when?) the drive fails then replacement is a problem......i have searched for solutions, but have not found anything other than spending a lot of money and sending the unit back to B&O...... anyone replace their own HDD...dare I ask about a SSD?
thanks
-michael
Søren Hammer
Denmark
The Beosound 3200 hard drive is likely just an ordinary 2.5" PATA drive, used often for laptops at the time. It can be a bit difficult to source a new drive, but new old stock should be easy; the issue is that we don't know how the drive is formatted and any possible software contained in the disk. These things becomes clear if mounted to a computer (A Linux partition is only recognizable on a Linux distribution though.)
You can't use a modern SSD with the Beosound as they use a different interface, called SATA. The reliability of modern HDD's is very good and should last a long time, they tolerate huge amounts of reads and writes.
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
TWG
TWG replied on Mon, Oct 19 2015 11:07 AM
easiest and safest way would be to clone the drive.
There are docking stations availabe that can clone harddrives with the push of a button. This way you can make a complete backup of the original drive without the need to know how it is formatted or what's on it.
s.th. like this: http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=hdd+clone+station
Page 1 of 1 (3 items) | RSS
