Does the configuration tool work with windows 10?
Piet
Noordwijk, The Netherlands
Posts 26
Piet Posted: Fri, Sep 18 2015 3:31 PM
For configuring my beo5 I have a 32 bits system running windows 7.
Does someone know I it still work if I upgrade the 32 bit system to windows 10?
Thanks,
Piet
Sweden
Posts 262
Martin replied on Fri, Oct 2 2015 1:25 PM
Hi, I have window 10 and it works perfect. I have config tool 6.62. Maybe earlier software will not work. But mine is working perfekt. Tried it yesterday.
/Martin
Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K
Piet
Posts 26
Piet replied on Sat, Oct 3 2015 11:24 AM
Thanks Martin for the response.
The version I use is also 6.62. My concern is the USB driver for the BEO5. This driver is only available for 32 bits systems.
So for that  I have an older system here with is 32 bits only. Are you sure that the USB driver for the BEO5 will work with WIN10?
Thanks in advance.
Piet
Page 1 of 1 (3 items) | RSS
