Beosound Century not reacting to remote
Answered (Not Verified) This post has 0 verified answers | 19 Replies | 1 Follower
Zwets
Zwets posted on Thu, Sep 17 2015 9:15 AM
Hoping this post finds more people who read it as opposed to the workbench forum;
My Beosound Century has stopped responding to its remote functions after a power failure. I have tried Sound-1-Store and Soud-0-Store settings but no luck. The unit otherwise works fine. My Beo4 remote also works fine with other kit.
Any ideas?
Zwets
Zwets replied on Fri, Oct 7 2016 12:56 PM
Thanks. I will try this weekend. I am in Holland
Bobby67
Hi.
Tkanks for good advice.
It's worked properly for me in first try.
Best regards
Bobby
Bobby67
Hi again.
I just chance the 3 condensations on the IR PCB board. In the middle of the B&o Century in the right side af the glas door you can se the IR print board.
Best regards Bobby
Bobby67
Suggested by Bobby67
If others have the problem with the remote control - no reaction - then you have to change only 2 small condensators on the small IR print board,
Price less then 1 euro.
The print board are mounted on the mother board and you can easily see it if you take the front of the Century.
Scalyfin
Thanks Bill, this fixed my problem, the little rubber pad had come off, back on all fixed. Thanks again. Ken
Page 2 of 2 (20 items) < Previous 1 2 | RSS
