Beosystem 3 & Apple TV Connection Issues
Answered (Not Verified) This post has 0 verified answers | 6 Replies | 1 Follower
dontneeditbutwantitnow
dontneeditbutwantitnow posted on Tue, Sep 15 2015 10:08 PM
Hi all I am interested to know if any member has any first hand knowledge or recommendations with the following issue:
System setup:
Beovision4 65 / Beosystem 3 / Beolab 9000 Mk11 / Beolab 6000 / Beolab 7.1 / beo link passive amp Beosystem 3 & BV 4 connected Sky box via Hdmi lead no problem sound & video output in BV 4 65  but not to outside speakers , was suggested to connect start lead from Sky Box to scart input in same av bank as sky connection . Successful!!! Sound output to outsid via beo link passive amp.
connect Apple TV via HDMI cable sound & video via TV all working fine!! No audio via Amp to outside speakers! Suggested to connect as above but with optical audio out of Apple TV to Digital Audio to digital coaxial converter & connect to SP/ DIF in second bank  altered input on Beosystem 3 for Apple TV to Audio input SP/DIF But no Audio output from Beolink Passive Amp !!!! Switch over to Sat & sky audio on TV & Outside via Passive Amp switch back & select Apple TV input & audio & video on TV but no Audio via amp to outside speakers!!!!
tried power down & repower of Apple TV but no luck
can anyone help Please??
Thanks in Advance
kallasr
Germany
As I understand you need analog sound for your outside Speakers (=link room speakers).
See this for example: http://forum.beoworld.org/forums/p/8466/74636.aspx
Ralf
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55
Home Office: Beovision 10-40 on STB Bracket wall mount. Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers
Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all white, wall-mounted)
Millemissen
Flensborg, Denmark
You'll need a DAC for the optical out of the ATV to a R/L analog input on the BSys3.
Only 'analog sound' can be distributed to the linkroom.
Raeuber
Germany
Raeuber replied on Wed, Sep 16 2015 12:13 PM
I use this small box for many years without any problems for sound distribution in my masterlink system:
http://www.amazon.de/Konverter-Wandler-Digital-Toslink-Koaxial/dp/B005H5JTMI/ref=sr_1_2?ie=UTF8&qid=1442401735&sr=8-2&keywords=konverter+digital+zu+analog
BTW: With the new Apple TV 4 this is not possible anymore because ATV 4 doesn't have an audio output anymore. Very sad indeed.
Regards
Räuber
Millemissen
Flensborg, Denmark
Then we will have to use a 'HDMI audio-debedder' instead.
there is always a solution ;-)
Millemissen
Flensborg, Denmark
Suggested by sromdusan
Sorry - the device is called 'HDMI audio de-embedder'.
Raeuber
Germany
Hello MM,
I think this one would do the job:
http://www.amazon.de/Ligawo-®-HDMI-Decoder-Audiosignal/dp/B00ADJIVB8/ref=sr_1_21?ie=UTF8&qid=1442413289&sr=8-21&keywords=hdmi+analog+wandler
But I also think you will need the new remote, even if there will be a PUC update available.
Regards
Räuber
Page 1 of 1 (7 items) | RSS
