BEOLIT 15 and BEOPLAY A2 NEW STEREO MODE FROM 27 AUGUST!
Not Answered This post has 0 verified answers | 33 Replies | 1 Follower
Emil Jensen
Denmark
Emil Jensen posted on Thu, Aug 20 2015 1:47 PM
http://www.recordere.dk/2015/08/saet-to-baerbare-bo-hoejttalere-sammen-til-stereo/
link
It is in Danish, but now you can use two Beloit 15 or A2 in a stereo setup!
Beovision Eclipse, Beolab 5, Beolab 17, Beosound 1 Google assist, Beoplay M3, Beoplay H6, Beoplay Earset
BeoMegaMan
rfrichg:
Millemissen:
More Bluetooth platforms are supporting this, Nokia had a Bluetooth speaker which could the same for more than 2-3 years ago.
But you are not sending more than one stream, then the first speaker will receive the stream an repeat it to the one which has been paired with the first one.
Then one is playing left and the other right, will be exciting to hear A2 and Beolit 15 which has True360 I'm not sure this will work super on a left only signal, if that's how it is implemented.
That's exactly how the technology works. It pairs to one then sends the signal through that pairing to the other.
Ah, you know... A little B&O here, a little there
tournedos
Finland
The Nokia speakers were very clever in that they would automatically switch to stereo mode whenever two paired speakers were in range. Hope B&O added that extra touch as well! (Unless it's patented Big Smile )
--mika
Chris Townsend
Badsey, UK
I have an A2 and a Beolit 15. Will they work together and how do I update the software?
Beovision 10, Beolab 2, Beosound 2(old Skool) Beolit 15, Beoplay A2 Active
Duels
England
Duels replied on Thu, Aug 20 2015 5:33 PM
I would imagine you would want two identical speakers to get the benefit of shoos stereo sound Chris.
mjmedlo
Millemissen:
...and makes much easier, if you divorce.
Big Smile. Exactly
Millemissen
Flensborg, Denmark
BeoMegaMan:
rfrichg:
Millemissen:
They promise:
'Minimal audio coding delay and latency.'
Millemissen
Flensborg, Denmark
I found an interesting paper on this issue (an more) - for those, who want to dig deeper:
http://www.ijetae.com/files/Volume2Issue2/IJETAE_0212_27.pdf
AnalogPlanet
Vienna, Austria
ONLINE
Duels:
I even suspect he was more likely interested whether he can "join" them and put in different places. Like you said, "stereo" from two different speakers does not make sense.
Btw, cool feature B&O. Can work also for friends joining their A2s or Beolits in a party. <3
"Bring your own sound channel" ;)
rfrichg
Millemissen:
I don't think it will support more than 2.0 and my guess are that they are using the aptX technology which offers different encoding and decoding depending on the propose.
The two speaker solution is not low latency so properly not good enough for TV, and it will not be the as good as CD quality either as far as I know (but my guess is that you can't hear the different on speakers of this size), correct me if i'm wrong :-)
BeoBoy68
FRANCE
BeoBoy68 replied on Thu, Aug 20 2015 10:06 PM
For your information:
Devialet Phantom support 24 speakers together. Big SmileYes - thumbs up
Duels
England
Duels replied on Thu, Aug 20 2015 10:08 PM
Then you are on the wrong forum beoboy
BeoGreg
South of France
BeoGreg replied on Thu, Aug 20 2015 10:58 PM
Had a look at the Devialet stand in Harrods, those products look like hoovers.
Jonathan
Melbourne, Australia
Jonathan replied on Fri, Aug 21 2015 12:47 AM
BeoBoy68:
Stop advertising your dodgy speakers in posts
x:________________________
Sweden, Skövde
Martin replied on Fri, Aug 21 2015 5:03 AM
If it uses aptx then does the stereomode work with Apple products?
Sweden, Skövde
Page 2 of 3 (34 items) < Previous 1 2 3 Next > | RSS
