Setting up Beolab 6000 to a beo 7.40 TV
Not Answered This post has 0 verified answers | 16 Replies | 0 Followers
KeithMM
KeithMM posted on Mon, May 4 2015 9:57 PM
I'm struggling to set up my Beolab 6000 speakers to my 7.40 tv can anybody help?
kallasr
Germany
do you have any other speaker (beolab 7) already attached to the tv or are the beolab 6000 the only speakers to be used?
Ralf
PS: If you download the manuals from the bang and olufswn website you will find all info needed....
Living Room: Beosystem 4, Beolab 7-6 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), no Subwoofer. Screen: Panasonic TX-P65STW60
Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55
Home Office: Beovision 10-40 on STB Bracket wall mount masterlinked to Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers
Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all white, wall-mounted)
Dave Farr
France
Struggling in what way? A bit of an explanation as to what the problem actually is would help.
Dave
KeithMM
I have a mk4 7.40 TV with its centre speaker! I am wanting to add two front  6000 speakers!
elephant
AU
KeithMM:
If you already have the two speakers all you need is power cables and two of any one of the three types of B&O power link cables.
Remove the 7-40's rear panel and plug the two power links into positions 2 and 3.
Or if you are daisy-chaining the 6000s just plug the first into position 2.
Set the switch on each 6000's base plate - one to LEFT and the other to RIGHT.
Then use the BV7's system to configure the speakers.
BeoNut since '75
elephant
AU
Here is what is under the rear connections cover panel:
BeoNut since '75
elephant
AU
Here are the system options on the configuration many for SOUND
If you need the next level of detail download the manual from this site if you are a paid member or from B&O
BeoNut since '75
elephant
AU
Final step is to add the SPEAKER soft button to the options under the [LIST] hard button on your Beo4 so you can switch between these speaker modes:
SPEAKER 1 ... Sound in the centre speaker only.
SPEAKER 2 ... Stereo sound in the front speakers. Subwoofers are active.
SPEAKER 3 ... The centre speaker, front speakers and subwoofers are active.
Enjoy !
BeoNut since '75
kallasr
Germany
Just to add if OP has an older Version (MK I or MKII without BS3):
Beolab 7 (Center Sound bar):
Beolab 6000 as Front speakers:
KeithMM
Many thanks for that:
6000 Daisy chained and plugged into the No2 sound panel.
Went into Menu  > DTV SETUP > OPTIONS > SOUND >
Then it shows me
SOUND SETUP:  Sub Menu   ADJUSTMENT    SPEAKER SETUP    LISTENING PRESETS    SOUND SYSTEM     AST ON/OFF
I've sort of worked between the sub menu but they are still not working, although the green light on the speakers does light up during certain aspects of the process, but having gone through the process and returning to the tv they switch off!
I'm obviously doing something wrong! :-(
Millemissen
Flensborg, Denmark
You probably havent 'stored' the new settings before leaving the Setup menu.
If not, the tv returns to the former settings.
Seanie_230
UK
Hi Keith
Glad we sorted it on the phone. Start with speaker type then roles.
Lastly we had to change default video from 1 to 3 and we were there.
Remember to check SKY HD Dolby is set to HDMI.
Glad your enjoying my old 7-40 I love my 7-55
BLGW - Rekindling the love of ML
elephant
AU
Good work Seanie !!
Thanks Kallasr for the earlier versions' diagrams !
BeoNut since '75
KeithMM
Thanks for all your help .... greatly appreciated! Loving it Smile
KeithMM
now wondering where I put the IR connector to work the sky HD Box!
Page 1 of 2 (17 items) 1 2 Next > | RSS
