Beogram 1202 annoying hum
Not Answered This post has 0 verified answers | 5 Replies | 1 Follower
callan
callan posted on Mon, Apr 20 2015 9:51 PM
Hi, I have recently purchased a Beogram 1202 in what appears to be good order. It has the usual B & O 5 pin din output, though I am hooking it up to a modern Yamaha amp. I purchased a female adaptor with 2 rca's and an earth output also. The problem I'm having is when its all hooked up and the earth is screwed into the ground point on the amp there is a fairly weak signal on one channel, one seems ok, and a really annoying hum. I disconnected the earth and it still hums badly.
Any help here would be most appreciated!
Lee
Newcastle upon Tyne UK
Lee replied on Mon, Apr 20 2015 10:59 PM
Sounds like a bad adapter. Get in touch with Steve at Sounds Heavenly for a new one.
Lee
callan
callan replied on Mon, Apr 20 2015 11:26 PM
Thanks Lee, will do. Do you know if the 1202 needs a pre amp before connecting to an amp? There are conflicting views on this I'm wondering if this might be part of the problem too?
Søren Mexico
Mexico City
The 1202 has no build in preamp, so if there is no preamp in your amplifier you will need a preamp
Søren Mexico
Mexico City
to which amplifier do you connect ?
callan
callan replied on Tue, Apr 21 2015 4:10 AM
Hi, it's a Yamaha RX-V667, I dont think it has a preamp so will contact Sounds Heavenly
Page 1 of 1 (6 items) | RSS
