Configuration Tool version 6.84 & Win7 64 Bits & USB problem
This post has 5 Replies | 2 Followers
hackel
Posts 30
hackel Posted: Sun, Apr 19 2015 4:10 PM
Hello,
I've got the last config tooll 6.84 and got a problem with my Beo6, There is no problem until the end of the serialization. Then the config tool tell me there is a problem with the USB drvier and after nothing to do to put the new program on the Beo6.
When I look at the message in the tray, I wonder Why Win7 try to install Beo5 ?? I'm programing a Beo6 not a Beo5.
The program tell me to disconnect the battery during 2 minutes but I don't have the tools to open my Beo6 !!!
Is the last config tools ok with Win7 64 bits ?
Thank you for your help.
zenadu74
Posts 2
zenadu74 replied on Tue, Apr 21 2015 7:16 AM
Can you kindly send me the Configuration Tool version 6.84 ?
zenadu74@hotmail.com
I just purchased Beo5 remote but don't have any software for my PC(Window8)
hackel
Posts 30
hackel replied on Tue, Apr 21 2015 3:27 PM
The last config tool doesn't work with a Beo5 but only with a Beo6.
Amazone
Netherlands
Posts 187
Amazone replied on Tue, Apr 21 2015 9:27 PM
6.84 seems very hard to get, so I guess there are only few beoworlders able to assist. I have 6.64 which was working for a while on win7/64. Then it stopped and produces an error while downloading to Beo6. Now im back to 6.00 from a Win7/32 which seems the most stable version to me.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
hackel
Posts 30
hackel replied on Tue, Apr 21 2015 11:05 PM
I'll test it on a Win XP PC I always have this week and tell you if it's ok.
Solex
Netherlands
Posts 103
Solex replied on Wed, Apr 29 2015 6:03 PM
I had also this problem on Windows 8.1. Seems USB driver problem in win 8.1. Use windows XP or windows 7 and problems solved.
Beovision 10-46, Beo6, Beosound 5+ Beomaster 5, Beolab 12.2, Beolab 12.3, Beocom 6000
Page 1 of 1 (6 items) | RSS
