Hi!
Basically there is no output from either of my BC2000s I have finally got around to tinkering with. Where should I start the process of finding the issue?
BC2000 #1 - New belts and motor from Dillen. Tape FF, RW, Stop and Play all move the tape as expected. No sound when I play tapes (tried through BM3000 and BC5000). Output level lights to 0db
BC2000 #2 - Switched out tape deck with repaired unit from BC2000 #1. No sound from this one either. Output level lights to 4db
Could the 'no sound' be due to a faulty tape deck, or is there some thing wrong somewhere else in both BC2000s? If the former I will switch over the new motor and belts to BC2000 #2's tape deck. If the latter I am a bit lacking in knowledge😳
Thanks for any advice.
Love = My Beomaster 1001 + Beovox 2700
#2: Missing 8Vref - replace the two 220uF capacitors on the Dolby board.#1: Probably the same cure, though the symptom is a little unusual.
Don't swap the drives permanently, quite a bit of calibrating would be needed to match the main board with the new drive.
Thanks!
Is it OK to switch the motor from one drive to another?
#2 sounds like the best bet to fix. Unfortunately its cover release was snapped in transit; of course it is part of the main chassis. Will consider transplanting it's guts over to the #1 body; if the caps fix the issue.
If I have trouble getting the caps I might add them to my pending order with you 😉
Thanks again
The motor speed can be adjusted directly on the motor and there are no other adjustments related to it, so yes, they can be swappedquite easily. You're welcome.
Well done!
The caps are not in the signal path, they are merely filtering a voltage.No need for any fancy stuff here.
Hi Dillen / Martin
I have just had exactly the same problem which has been rectified by exactly what you suggested ...
... BRILLIANT !! ...
many thanks
Pete
Welcome and thanks for letting us know.Dont' be a stranger now.
I have the same issue with a Beocord 3500. Everything works except no sound. There are no light/respons in VU meter.C417 is changed - same issueC212, C214, C412 and C414 changed - same issue.There are 9,2VDC at C417, at little higher than schematic (7,4V).Are there any suggestions what might be the cause?
/Pindsen
I managed to locate the issue. IC2 on the Dolby board was defect forcing the Beocord into REC mode when it should be in playback mode.
This occidentally erased my tape, so be careful using a tape with no value when troubleshooting :-)
