The Beosound 5 / Beomaster 5 resources future proof maintenance thread
This post has 30 Replies | 10 Followers
TWG
Posts 1,284
TWG Posted: Fri, Apr 3 2015 10:50 AM
Dear Beoworlders,
as here are enough of us who take care of our lovely B&O items, repair them, maintain them to share the love for even >30 years old products, I think it is a good idea to dedicate a thread ONLY to the Beosound 5 / Beomaster 5 system.
My idea is that we share resources, hints, repairing tips, service tips, technical information, how-to's in one thread. That will make it easier to find and follow the information for us when needed.
As the Beomaster 5 is a Windows XP embedded based system it seems to be much trickier to keep it running considering stuff like dead mainboard, harddisks, closed Windows XP support etc.
So, you're welcome to add your stuff, links (Beoworld and external) etc. to make this useful for all of us.
I still like the design and haptics of the Beosound 5 even if it's not the post intuitive music system on this planet. ;-)
For example
- cloning Beomaster 5 HDD
- exchange motherboard
- successfully from HDD to SSD
- deal with the serial numbers
- softwareupdates
- tweaks
We had a thread like this for the old Beomedia 1 with a lots of tricks and instructions and I think it was a very good idea!
btw: Happy easter! Big Smile
beolion
Posts 319
ONLINE
Silver Member
beolion replied on Fri, Apr 3 2015 11:37 AM
Agree.
riverstyx
Exeter, Devon, UK
Posts 891
riverstyx replied on Sat, Apr 4 2015 12:42 AM
Excellent idea. Here's a little info to get the ball rolling:-
My BM5 was supplied with a Western Digital WD10EURX 1TB hard disk which I have successfully replaced with the equivalent 2TB model (WD20EURX). I have packed the original drive away in a safe place and also saved a disk image on my NAS, both as an aid to any future recovery should the drive fail. I would suggest all owners should consider at least one of these options. I used clonezilla to clone the drives as it is much faster than a block by block copy of the entire disk as it understands the file systems and therefore does not need to copy unused space (this speed advantage would be less significant if your existing drive was almost full, but I cloned my disk before I copied my music onto the BM5).
I have also considered acquiring a replacement motherboard - my initial research indicated the following:-
  • The motherboards is a VIA EPIA EX fitted with a 2GHz VIA C7 processor but retail versions of this motherboard came only in 1GZ and 1.5GHz guises so I assume the 2GHz version was built to order for B&O.
  • The processor is not socketed but rather soldered (BGA), so a change would not be straightforward although BGA chips can be changed with the right equipment and there are plenty of companies who can provide this service.
  • The serial number is stored in the BIOS and on the Hard Drive. Cloning the hard drive properly will copy the serial number to the new disk so this is not an issue but the serial number in the BIOS might be.
  • There is a B&O software tool that copies the serial number from the hard drive into the BIOS when replacing the motherboard but this is obviously only available to B&O service technicians.
  • A previous forum post suggested that the VIA BIOS software tool could be used to save the B&O specific BIOS but not the serial number data which is stored in a special protected area of the BIOS.
  • It was my intention to check whether the BIOS is socketed, and if so whether I could take a copy of the full BIOS, including the serial number data, using my EPROM programmer, but I haven't got around to doing so yet.
BeoMotion
Posts 371
BeoMotion replied on Sat, Apr 4 2015 10:06 AM
here are two software solutions that require no separate hardware.
BeoSound 5 and AirPlay:
LINK TO THREAD
BeoSound 5 and Spotify Connect:
LINK TO THREAD (just scroll down a bit to read the instruction how to install)
A while ago Spotify announced that they are going to drop the support for Win XP at some point. So maybe this solution might not work in future and we will have to wait (or hope) until someone successfully reverse engineered the Connect protocol and programmed a little application like the shairport solution above.
BR,
BeoMotion.
TWG
Posts 1,284
TWG replied on Sat, Apr 4 2015 11:17 AM
Enable Beosound 5 MLGW / Masterlink Gateway compatibility mode to pass Light & Control signals through Masterlink:
Access to ‘Service Menu’:
Access to the ‘Service Menu’ can be obtained in 2 ways,
either from BeoSound 5* screen or from BeoMaster 5** (TV screen).
Please use the following procedure for a smooth setup:
* BeoSound 5, ‘Service Menu’ access (when no TV is connected):
- Move the navigator arm to MODE
Normal 0 false false false false EN-US JA X-NONE
and use the wheel to highlight SETTINGS.
- On BeoSound 5 keyboard,
press: > < > < GO
to activate ‘Service Settings’
(Service Settings appears in left side of the screen,
containing new sub menus).
- Move the navigator arm to MAINTENANCE
and use the wheel to highlight SERVICE MENU
and press GO.
Now all active sources related to BeoSound 5
or BeoMaster 5 shuts down,
Normal 0 false false false EN-US JA X-NONE
and the ‘Service Menu’ appears on the screen
Service Menu:
When setting up BeoMaster 5 a USB PC keyboard and mouse must be used.
Select/Open the folder MLGW
Enable commands to MLGW (Master Link Gate Way):
- Will enable reroute of all LIGHT and CONTROL commands from remote to MLGW.
- It is recommended only to have one product in a room with this setting to enabled
- Three or more products in a room can cause fail on ML
Enable status to MLGW (Master Link Gate Way)
- Shall only be enabled if status to a control panels is needed
Both settings are default disabled
riverstyx
Exeter, Devon, UK
Posts 891
This is straight from the FAQ section on the B&O website but I thought it worth including here as it took me a little while to figure this out when spotify first became available with audio master set to NO.
How do operate BeoSound 5 in a system with another audio system using Beo4?
When BeoSound 5 is set up in a system with another audio system (that is when AUDIO MASTER is set to NO on BeoSound 5), you can activate following sources using your Beo4 remote control:
  • N.Music
  • Spotify (provided that you have an account)
  • A.AUX
How to active a source with Beo4 ...
Source
Beo4, type 162x
(with GO button)
Beo4, type 171x
(with navigation button)
N.Music
  • Press LIST until N.MUSIC
    is shown in the Beo4 display.
  • Press GO.
  • Press LIST until N.MUSIC is shown in the Beo4 display.
  • Press the centre button.
Spotify
  • Press GO.
  • Press 1.
  • Press 1.
  • Press Play.
A.AUX
  • Press GO.
  • Press 2.
  • Press 2.
  • Press Play.
riverstyx
Exeter, Devon, UK
Posts 891
Also worth mentioning is that the CD ripper is just a USB CDROM drive in a fancy case, and as such pretty much any USB CDROM / CDRW / DVD etc drive plugged into the BM5 will be detected as a CD ripper and work in exactly the same way as the official B&O unit. I just bought a really cheap (<15GBP) slot loading drive which sits on top of my BM5 and then turned on the ripping functionality in the BS5 menus.
Admittedly I don't tend to use it much, as I prefer to rip my music on another machine in the format I want, but I've always felt the CD ripper somewhat spoils the aesthetics of the BS5 so having this hidden away with the BM5 is a better solution to me.
Martin.
BeoMotion
Posts 371
riverstyx:
Unfortunately this is only the half truth.
As you have mentioned almost every USB CD/DVD drive will work for ripping CDs.
What seams not to work with devices other than the original B&O one is the possibility to use it like a normal CD player.
At some point there was a software update that introduced this function.
Only with the ripping device you are able to see and use this source from menu.
It seams that the software is checking the VID/PID of the connected drive.
The ripping device shows this values:
USB 2.0-Hub: VID_05e3 PID_0608 REV_3298
USB mass storage: VID_13FD PID_0940 REV_0101
As you can see the VID it is not the B&O one. Maybe there are "normal" drives out there with the same VID/PID that will work for both ripping and playing CDs. Worst case would be if it is checking the hub IDs, too.
riverstyx:
totally agree
BR,
BeoMotion.
riverstyx
Exeter, Devon, UK
Posts 891
BeoMotion:
Interesting, I did not know this. A quick google seems to indicate there are indeed standard drives and hubs around with the same VID/PID so it may be possible to obtain the correct drive and gain the CD playback functionality too, but I don't use mine for playing CDs as I use either my BS9000 or the DVD drive of the BV7-40mk3 for that as both are in the same room as my BS5.
Martin.
Beoberg
Odense, Denmark
Posts 306
Beoberg replied on Sun, Apr 5 2015 4:38 PM
If anybody stumples upon a cheap CD drive that shares the same VID/PID, then please post it here :)
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay M5 (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 3 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
tournedos
Finland
Posts 7,278
BeoMotion:
According to the link below, that might point to an Asus SBW-06D2X-U:
http://askubuntu.com/questions/553907/external-bluray-unit-wont-mount
...but that isn't exactly cheap either. I suspect the VID/PID correspond to the bare Initio drive mech inside the Asus enclosure (and the ripping device), not to the entire unit.
--mika
riverstyx
Exeter, Devon, UK
Posts 891
tournedos:
Yes, it's actually probable that the VID/PID refer to the USB to SATA bridge so the drive itself may be entirely different. I found several references to these hardware IDs, some of which were for DVD/RW and also the Bluray unit above.
It may be the USB VID/PID that is being checked or it may be the drive identifier so to be 100% certain of success you'd need the same drive, running the same firmware, on the same bridge, and possibly connected to the same USB hub.
Maybe someone who owns the official CD ripper might be prepared to the case to see what drive is actually inside?
Martin.
Beoberg
Odense, Denmark
Posts 306
Beoberg replied on Fri, Apr 10 2015 12:06 PM
I can now confirm that the ASUS 06D2X-U blu-ray combo drive sort of works both for ripping AND for CD-playback. Sometimes you have to restart the BM5 for the CD playback to work. I am trying to fiddle with some of the options to see if I can get it to work 100%.
BeoMotion
Posts 371
BeoMotion replied on Sat, Apr 11 2015 2:10 PM
Beoberg:
Great! Thanks for reporting this.
Would be nice to know whether you can get it working perfectly.
BeoMotion.
Steph
France
Posts 962
Steph replied on Wed, Apr 15 2015 5:51 PM
Very interesting thread ! Yes - thumbs up
I liked the CD ripping device concept, but thought it ruins the overall design of the beautiful BS5.
So, a CD player connected to the BM5 is a really good option.
One thing : What USB port are you using to connect the device (2 ports are available below the RJ45 port), and is there anything to do in the service menu or in Windows mode ?
Thanks.
talisman
Sweden
Posts 50
talisman replied on Wed, Apr 15 2015 7:21 PM
Hi !
I have the B&O Beomaster 5 Service-tool. Is is on an copy protected USB Stick.
And you also need B&O Service tool MKII, to ad system img on beomaster 5 service-tool.
TWG
Posts 1,284
TWG replied on Thu, Apr 16 2015 8:21 AM
talisman:
Hi !
Wow! Now we need a local copy to archive and backup that software for future use!
Could you upload it somewhere for the forum?
talisman
Sweden
Posts 50
talisman replied on Thu, Apr 16 2015 11:18 AM
No !
TWG
Posts 1,284
TWG replied on Thu, Apr 16 2015 11:24 AM
talisman:
No !
it's digital... so there IS always a way to make a backup of it. Wink
And this software could help to fix a damaged Beomaster 5 by yourself (new mainboard, serial-numbers of the hardware etc.)
steve1977
Posts 576
steve1977 replied on Sat, Apr 18 2015 10:19 PM
Anyone succeeded to add alac codec?
Beobuddy
Utrecht, The Netherlands
Posts 3,328
talisman:
No !
Create a bootable stick and copy the files on it. Voilá. Whistle
BeoMotion
Posts 371
Today I had a look at the BeoSound 5 USB communication.
Quite easy and straightforward.
Wrote a little program and hooked up the BeoSound 5 via USB and HDMI to a Raspberry Pi.
Worked flawlessly including full button / lever / ring / volume-wheel support.
So if there comes a time when there are no spare parts for the BM5 available any longer this would be an alternative.
Just add a good DAC and maybe use XBMC with a highly modified UI.
Hopefully there will also be some open ML stuff in future. We are working on this in another thread...
BR,
BeoMotion.
riverstyx
Exeter, Devon, UK
Posts 891
riverstyx replied on Sun, May 3 2015 12:43 AM
BeoMotion:
Good work - I've been meaning to do this myself  As a USB HID device, my guess was that the various controls would act in a similar manner to X / Y axes of a USB mouse, can you confirm whether this is the case?
Martin.
BeoMotion
Posts 371
BeoMotion replied on Sun, May 3 2015 10:25 AM
riverstyx:
It is indeed detected as a HID device and there are some similarities to e.g. a mouse but it is not the same.
There is one EP (interrupt) and if you listen to it it will return an array with all values if something changes.
It will give you two values with the click count of the both rotary wheels since the last read (counting from 0 if clockwise or from 256 if counter clockwise).
Then there are two identical absolute values from the lever, a value for the buttons and one that I don't know. This might be for IR since I forgot to test this.
BR,
BeoMotion.
geencar
Posts 6
geencar replied on Sat, Sep 26 2015 3:17 AM
I would like to follow the alternative thread as mentioned, where is it to be found?
Regards
Geert Veen
geencar
Posts 6
Regards
Geert Veen
steve1977
Posts 576
steve1977 replied on Sat, Nov 14 2015 6:09 AM
BeoMotion:
BR,
BeoMotion.
I don't know how I could have missed this. This indeed reads very exciting. Would this only work with a BS5 or also with the BS5E? If XBMC/Kodi could show the UI and then paly on my BV, this would be really cool!
Carolpa
Posts 762
Carolpa replied on Sat, Nov 14 2015 10:09 AM
take notice that Microsoft stops support of XP embedded on 12 January 2016.
the new project should be Windows 7 or 8 embedded.
I had it almost working on a BM1 than I did something stupid and lost the B&o partition
gerard
Luxembourg
Posts 188
gerard replied on Wed, Mar 29 2017 7:05 AM
As I'm a new owner of a preloved BS/BM5 , I'looking to get it future proof.
I'affraid reading that the mainboards seem to beak down.
Did anyone of you get new infos on :
- changing the mainboard,
- upgrading the OS to win 7, 8, 10.
- copying the BM5 service tool
let's reactivate this important threat!
Thank's
MJBeo
Netherlands
Posts 213
MJBeo replied on Thu, Aug 3 2017 10:38 PM
Also here to bump this thread.
Using the panel of the BS5 to control a raspberry pi would be awesome, I do not care at all about the BM5 as my BM5500 is rocking it.
Beosystem 5500 + Playmaker MKI + RL60.2 / MCL2 A + RL35      BV7-32 MKIII + Raspberry Pi3 + Lintronic -238 + MCL2P & CX50 / Cona     4 link rooms with MCL2 A / MCL2 A/V + MCL2P  + CX100 / CX50 / Grundig 210a     Various Vintage restore objects
TWG
Posts 1,284
TWG replied on Fri, Aug 11 2017 9:51 AM
riverstyx:
I checked the price of the motherboard a few years ago (out of curiosity) and if I recall correctly it was in the region of 400 to 500 GBP.
As Beobuddy mentioned, there are additional sockets on the stock Epia EX board although you should be able to desolder these (or perhaps even snip their legs off) to make the board fit.
As long as the bios chip on the original board is still working you may be able to simply swap it out to the new motherboard and avoid the need for the service tool.
I did remove the bios chip from my BM5 a while ago to take a backup copy of it (using an EPROM programmer) and it is my intention at some stage to have a play with the linux flash tools to see if I could flash a stock EX motherboard accordingly without resorting to removal of the chip, but it's one of those tasks on my todo list that is unlikely to happen until a motherboard failure in my BM5 forces it higher up the list!
Martin.
BeoBuddy:
The Epia EX board will not fit easily into the casing of the BM5. The original EX has sockets which are not present in the BM5. Like digital audio out.
It will partly work. You will have to flash the B&O Bios in the EX, But you need the B&O servicetool to copy the serialnumber in the BIOS. Otherwise you will not get any updates. The Epia flashtool isn't capable to flash the serialnumber.
The reason I think many B&O boards fail, is that they run the processor on 2.0Ghz, instead of the normal 1,5Ghz. That's causing more heat, and there is't an active cooler on it.
Page 1 of 1 (31 items) | RSS
