Beolab 5000 broken slider
Answered (Verified) This post has 1 verified answer | 10 Replies | 1 Follower
bugge
bugge posted on Sun, Jun 3 2012 5:26 PM
Hi everyone!
Long time fan, first time poster here Smile
I was very lucky and got my hands on a Beolab 5000 a couple of days ago, but the problem is that the volume control slider is broken. The glass is cracked and the metal part (the one that has "volume" printed on it) is gone.
Does anyone know of a way to get a hold of a replacement part?
After looking at pictures i see that maybe the sliders on the Beomaster 3000 looks similar, does anyone know if this is correct? Because I may be able to get a hold of a defect beomaster 3000 and use the sliders from that one.
The measurements of the beolab 5000 slider is:
  • Width 25mm
  • Height 35mm (top of the top metal part to bottom of the lower metal part)
  • Depth of the metal part 6 mm
Thanks in advance
Dillen
Copenhagen / Denmark
Verified by bugge
The Beomaster 3000 and Beolab 5000 windows are not identical.
They are apprx the same width and height but thicknesses are different.
Beolab 5000 have thicker window areas whereas the Beomaster 3000 have thicker flanges.
Leslie
the Netherlands City
Silver Member
You mean these? Made them myself a while ago...
Brengen & Ophalen
Leslie
Silver Member
bugge:
No, it's not!
Brengen & Ophalen
bugge
bugge replied on Sun, Jun 3 2012 6:20 PM
Leslie:
No, i mean the volume slider.
Its like this one
Leslie
Silver Member
Probably it is (3000-5000)? Always mixing lab and master. Was expecting the amp to be the Beolab instead of Beomaster (why is that?).
I stored my Beolab and Master away so I can't check for you at the moment. I'sm sure others can confirm if  3000 sliders are compatible with 5000.
Or as said before, make them yourself....
Brengen & Ophalen
Dillen
Verified by bugge
bugge
bugge replied on Sun, Jun 3 2012 9:09 PM
Thanks.
Then I will try to make them myself
Leslie
Silver Member
Good thing and show us the results! Smile
Brengen & Ophalen
bugge
bugge replied on Wed, Jun 6 2012 12:27 PM
Leslie:
Ok, I got a plexi glass pice with the right thickness and after a heavy use of sandpaper this is the result Smile
Sorry about the picture quality, my camera is not the best
I am very pleased with the result, and the only thing left now is to add lettering. I think i will try with some sort of transfer paper. Anyone know the font? Is it helvetica?
tournedos
Finland
Well done! Yes - thumbs up
Helvetica is indeed closest - Letraset should have some transfer letters that will be a close match.
--mika
Leslie
Silver Member
Leslie replied on Wed, Jun 6 2012 10:07 PM
Told ya, with some effort....Smile
Brengen & Ophalen
Page 1 of 1 (11 items) | RSS
