Beolink converter NL/ML manual
Answered (Verified) This post has 1 verified answer | 15 Replies | 2 Followers
doun
doun posted on Fri, Mar 13 2015 9:34 AM
Hello,
Could somebody give me the link to, or send me, the Beolink converter NL/ML manual that explains how to configure it?
Thanks in advance.
Didier
mjmedlo
Verified by Flenser
https://www.dropbox.com/s/u0t5d3esjvtozoy/BLC_NL-ML%20Installation%20Guide%20Ver.%201.2.pdf?dl=0
elephant
AU
doun:
Hello,
Thanks in advance.
Didier
http://www.bang-olufsen.com/en/customer-service/product-support/accessories/beolink/beolink-converter
BeoNut since '75
doun
doun replied on Tue, Mar 17 2015 4:42 PM
Hello,
First, thanks for your answer.
But I am looking for something more detailed. Is it something you plug and it works? No configuration needed?
Kind regards,
Didier
mjmedlo
Verified by Flenser
lano
lano replied on Tue, Mar 17 2015 10:19 PM
Thanks for a very good document. I have two additional questions that I couldn't find an answer for.
1. Is it possible to control the BLC from the MLGW if you connect speakers to the BLC (and use it as a Beolink active)?
2. Can you send the AUX (line in) to the ML and listen to that source in other room (for example Beolink active)?
BeoMegaMan
The BLGW will not act as an active type system similar to the NL converter.
You can share the source from a NL converter to a ML based system as long as the source name isn't already in use on the ML system.
Ah, you know... A little B&O here, a little there
doun
doun replied on Tue, Mar 17 2015 11:18 PM
Thanks for the document.
I really appreciate.
Best regards,
Didier
linder
United States
linder replied on Tue, Mar 17 2015 11:46 PM
mjmedio,
Thank you for this link.  I have been waiting to see this document for a long time.  I now know why the converter is priced at around $1000 USD.
It use to be that a Bang and Olufsen system regardless of price was relatively easy to setup for the average user.  This is not the situation anymore.
lonfred
Thank you for this mjmedlo!!
lano
lano replied on Wed, Mar 18 2015 5:57 AM
I meant if the BL/ML converter (BLC) count be controlled by MLGW in the same way as a Beolink active can when you have attached speakers to it. Or is it only IR control that is possible?
berlin2010
lano:
Don't have MLGW but control my Converter (with speakers attached) via B&O smartphone app (no IR) so can't imagine MLGW would be any different?
lano
lano replied on Wed, Mar 18 2015 8:49 AM
Which app is that?
Millemissen
Flensborg, Denmark
linder:
mjmedio,
Converting from one analog based protocol to another - like with the old ML/MCL Converter - is not a big problem.
Converting from the (ML) analog protocol to (NL) digital protocol and vice versa is much more complicated.
The current B&O setups can include quite a lot of different (new and old) products, that we (as costumers) expect to work seamlessly together.
Of course this makes it rather complicated to set up - especially in bigger setups. Normally an experienced installer should do this, which is the reason, why the manual is not online on the B&O site.
And then there is the benefit of the included 'Active Link function'. And the possibily for online updates.
These things must lead to a relatively high price.
We should be gratefull, that 'our company' has invested quite a lot of time and manpower to make older and newer A/V products compatible as far as possible.
Which other company would do this? 'Throw your older gear in the bin and buy new stuff instead' seems to be the motto of most other electronic product manufacturers.
mjmedlo
lano:
Which app is that?
You can use the beoremote app to select source etc.
Any network link source will function from beoremote. (I think)
You won't get any macros or scenes etc.
All the beoremote will do is work the active kit section of the converter. The converter is much more than an active kit though.
doun
doun replied on Thu, Mar 19 2015 8:23 AM
Hello,
I have a question concerning the Network link. I understood that it is important to have another router that the ISP router to isolate the internet traffic from the Beolink traffic.
I have a NAS. If I am referring to the document, the NAS shall be connected to the Beolink network. The NAS will be visible from my Beovision but now it won't be visible from my computer which is on another subnet.
How to configure the Beolink router to give access to the NAS from another subnet in my network?
Thank in advance for your help.
Didier
Page 1 of 2 (16 items) 1 2 Next > | RSS
