Tune BM7000 with Mk2 Beo4 and store presets
Answered (Verified) This post has 1 verified answer | 5 Replies | 0 Followers
joeyboygolf
Ely, Cambridgeshire, UK
joeyboygolf posted on Thu, Feb 19 2015 8:40 PM
Can someone explain how to tune the radio in BM7000 with Beo4 and store in presets.
I have forgotten as it is so long ago that I had to do it.
Regards Graham
jojoe
Silver Member
Answered (Verified) jojoe replied on Tue, Nov 22 2016 3:53 PM
Verified by jojoe
what is option 2 ? How do put the beomaster into option 2? with a BEO4?
tournedos
Finland
It is somewhere on the forums and I have no idea where - but the core of the trick is to put the Beomaster in option 2 so that it will follow video commands as well, and then you can use the TUNE command that is found in the list of Beo4 (but only in video mode). I think you had to cover the remote while you press TV so that the Beomaster doesn't know what comes next, then dig up TUNE.
Buy a Beolink 1000 Big Smile
--mika
joeyboygolf
Aaah! Option 2! That's what I forgot.
Regards Graham
joeyboygolf
It works now!
Regards Graham
joeyboygolf
Aaah! Option 2
Regards Graham
jojoe
Silver Member
Verified by jojoe
Page 1 of 1 (6 items) | RSS
