BS9000 IR Remote Problems
Not Answered This post has 0 verified answers | 32 Replies | 3 Followers
machineage
United Kingdom
machineage posted on Wed, Jan 28 2015 9:40 PM
Hi All
I have just acquired a BS9000 Mk1 & a pair of Beolab 5000 speakers. The BS9000 is working fine - as are the speakers & displays.
However the BS9000 responds to input via the manual keypad - but not remote. I have a BL 1000 and have entered SOUND - 1 - STORE whilst the unit is in standby. The standby LED doesn't blink and it still won't respond to the BL 1000. I have also tried with a Beo4. Mine is an early version & the display doesn't flash when you press standby & list - but I can get to 'A Opt.' and then press 1. Again no LED flash from the BS9000 & no response from either IR remote.
Any ideas anyone?
Thanks!
Jack
Poland
Service manual:
1. Glass lid
2. Left aluminium plate
3. Release of sledge
4. Cover for chassis top plate
5. Chassis top plate
PCB14 IR Receiver:
- Carry out points 1 to 5.
- Remove 35P53, power supply for sledge motor, and 26P96.
- Remove the screws for the top plate (C, D, E) (see under point 10), lift the top plate carefully (approx. 2 cm), and carefully pull the top plate a little to the right.
- Remove two screws for PCB14 and lift off the PCB.
If IR does not work probably C9 lost the capacity. I had to adjust the 455kHz L1 and L2 filters several times because they were not tuned.
Weebyx
Denmark
Weebyx replied on Thu, Jul 1 2021 12:58 PM
Jack:
Service manual:
1. Glass lid
PCB14 IR Receiver:
How did you adjust L1 and L2 ?
/Weebyx
Teyelvis
Is it still possible to order a new ir pcb for mk1?
Page 3 of 3 (33 items) < Previous 1 2 3 | RSS
