BS9000 IR Remote Problems
Not Answered This post has 0 verified answers | 32 Replies | 3 Followers
machineage
United Kingdom
machineage posted on Wed, Jan 28 2015 9:40 PM
Hi All
I have just acquired a BS9000 Mk1 & a pair of Beolab 5000 speakers. The BS9000 is working fine - as are the speakers & displays.
However the BS9000 responds to input via the manual keypad - but not remote. I have a BL 1000 and have entered SOUND - 1 - STORE whilst the unit is in standby. The standby LED doesn't blink and it still won't respond to the BL 1000. I have also tried with a Beo4. Mine is an early version & the display doesn't flash when you press standby & list - but I can get to 'A Opt.' and then press 1. Again no LED flash from the BS9000 & no response from either IR remote.
Any ideas anyone?
Thanks!
Beobuddy
Utrecht, The Netherlands
ONLINE
And the second one.
Beobuddy
ONLINE
Beobuddy replied on Thu, Jan 29 2015 10:05 PM
Replacing the board at that side means dismantling of the alu plate from it's plastic body. A rather time consuming job as the sledge slides through the bracket mounted on/beneath the alu plate.
Beobuddy
ONLINE
Beobuddy replied on Thu, Jan 29 2015 10:07 PM
Most user uses the BS9000 with a Beovision. Then the commands comes via ML from the BV as the speakers are attached to the BV then.
machineage
United Kingdom
Thank you Beobuddy for your detailed reply!
I have looked again at the IR receiver PCB located by the CD platter - and it looks fairly clean even though it is quite hidden. I wasn't aware of the IR receiving diode by the standby button. So I tried again with both remotes pointing directly toward it. Still no response.
I guess it's looking more & more likely the PCB is faulty Sad
Beobuddy
ONLINE
Despite the fact that parts hardly available are for the mk1, the ir PCB from the mk3 is slightly different, but fits perfectly.
The small ir-PCB doesn't cost much. Labour will be a bit more. can be done within 1-2 hours if the technician keeps the sledge in the first position to provide enough space the change the PCB.
machineage
United Kingdom
Thanks Beobuddy
I wonder what the chances are of finding a used PCB14 from a BS9000 that is being broken for spares... Any idea of the cost of a new PCB14?
How difficult a job is it? I am an engineer and have worked on many electronic devices over the years Smile
Thanks again
stefan
200 miles from Struer
stefan replied on Fri, Jan 30 2015 11:12 AM
Before trying to find another PCB, I`d try to activate the BS9000 and change the option setting by using a Powerlink dummy plug.
Disconnect your BL5000 (you are talking about BL5000 panel speakers from the 80s with orange display?), get 7 pin DIN plug, solder a bridge between PIN 4 (5V) and PIN 2 (ground). Plug the dummy into one of the Powerlink sockets, reconnect your BS9000 to the mains, wait a minute and try to set the system to A.OPT 1.
I`m not sure if this helps, but maybe worth a try. BL5000s are a bit special. They are not be activated by PIN 4, but by PIN 1. PIN 4 is for speaker mute.
BS9000 uses PIN 4 to check if Beolabs are connected.
Should be possible to test test this. Just press the mute button when the BS is active - BL5000 should turn to standby mode...(?)
You will find detailed info on the beotech site - wiring/powerlink.
Hope this helps...
Stefan
machineage
United Kingdom
Hi Stefan
Thanks for the reply.
I'm wondering if this is turning into a Workbench thread!
I was halfway through dismantling the BS9000 when your post came in Wink. A fairly logical procedure following the instructions in the service manual - I was about to remove top plate.
OK - in excitement I replaced everything. I opened one of the PL DIN connectors & shorted out pins 2 & 4 (Yellow & Signal Ground) & checked for continuity.
Reconnected just this PL lead - plugged the BS9000 into the mains and switched on the via the rear red pushbutton. Waited a minute - then tried again first with the BL1000 SOUND - 1 - STORE. No confirmation flash from the standby LED Sad
I tried also with the Beo4 as above - again nothing.
Before I reassemble the DIN connector - I measured the voltage from pin 4 to ground whilst the BS9000 is in standby which was 1.25v - is that acceptable?
OK - so I hooked up the BL5000 speakers (yes the ones from the late '80s with amber displays). Popped in a CD (death metal would have been appropriate under the circumstances) & powered up. Pressed CD on the manual keypad - and everything springs into life and CD playback begins. When I press MUTE on the BS9000 keypad - the sound quickly fades to mute - but the BL5000 displays remain lit with data & no relays activate in the speakers. Pressing MUTE again quickly fades the music back.
Sad
stefan
stefan replied on Fri, Jan 30 2015 4:12 PM
machineage:
This is strange. Voltage should be <0,5V when off, and >2,5V when on. PIN 1 is for Powerlink on and PIN 4 for speaker on/off.
This is for older Beolabs like BL5000, Penta... Now they use PIN 4 for Powerlink on, and I thought, your BS9000 is wired this way (my BS9000 is, but it`s an MKIII...)
You will find this info on beotech site (scroll down)
http://www.beoworld.org/beotech/wiring2.htm
Stefan
Beobuddy
ONLINE
No, it's not. It's a sensing mechanism which provides that low voltage.
With the latest mk3 penta's, pin 1 isn't used anymore. Pin 1 and 4 are connected internally in the penta. But as already mentioned by TS, the set works fine. Only ir doesn't work.
BTW. By shortening pin 2 an 4 at the BS9000 powerlink, the BS9000 starts in option 1. No futher option programming is needed.
Beobuddy
ONLINE
Don't search for a used pcb, just order a new one.
machineage
United Kingdom
Thank you guys
Yes the system works perfectly  - just no IR after all these tests etc.
I will look into the pricing on Monday. Should I just go to my local B&O dealer - or to B&O direct?
I will sit down for when they give me the price Big Smile
machineage
United Kingdom
OK guys - the PCB arrived today. I installed it - then with some hesitation I pressed SOUND - 1 - STORE on the BL1000 - and the standby LED blinked - HOORAH!!! I then pressed RADIO on the BL1000 and it sprung into life Big Smile
So it was the PCB after all.
Now - I have another problem with the test modes - that is for another thread I feel.
Thanks to all you guys for helping with this.
Choobi
Choobi replied on Tue, Jun 29 2021 6:55 PM
Hi Machineage,
I had the same problem as yours but I dont know how to remove the PCB for the IR receiver.Can you give me an idea how to remove it?If you dont mind.Thank you.
Choobi
Choobi replied on Tue, Jun 29 2021 7:02 PM
Hi Beobuddy,
Can you give me an idea on how to remove the IR PCB as seen on this picture?If you dont mind.Thank you.
Page 2 of 3 (33 items) < Previous 1 2 3 Next > | RSS
