BeoLab 5 Upper Woofer No Sound -- Anyone heard of this?
Not Answered This post has 0 verified answers | 14 Replies | 2 Followers
nmook
nmook posted on Mon, Jan 19 2015 7:05 PM
So my BeoLab 5s worked flawlessly for 3.5 years and then went into storage for 3 years. I recently took them out, hooked everything back up, ran the bass calibration, and played a CD.
One of the speakers immediately made a disconcerting sound (not a speaker pop, but something more digital), and does not output sound from the upper woofer. The subwoofer seems fine, and the top two tweeters are fine.
I had a service tech open up the BeoLab 5, and he removed and tested the upper woofer itself (multimeter, battery test) -- it's fine he said, no problems. So it appears to be something that is causing the electronics not to output any sound to the upper woofer.
The speaker itself shows no outward sign of a problem. It's green and functions just like my other BeoLab 5 -- without any sound coming from the upper woofer. The bass calibration also works fine, but it does appear to linger at one point -- the service tech said it was trying to hear sound from the upper woofer.
While the tech is investigating, I figured it couldn't hurt to ask if anyone has experienced anything like this before? Really hoping I don't have to spend a bunch of money on a replacement electronics module...
Thanks in advance for any ideas/input!
Lennart500
Hi Nmook. Did you find out what as causing the problem?? Both my beolab 5`s have same problem. Think its caused form overheating.
Best regards Lennart
nmook
nmook replied on Fri, Mar 4 2016 9:18 PM
We tried replacing the mid-range speaker, but it didn't help. The tech had to replace the entire circuit board for the speaker. It cost around $900, I believe.
Mr 10Percent
So West, Its Now East
I've just swapped-out my two upper tweeters. One had weakened to a point where very little was coming out of it and on replacement found that the other was not performing as well as the new unit. Thus two new upper tweeters of the same age replaced. Beolab5's as good as new now.
Somewhat behind the diagnostic curve on your issues but I would recommend playing L then R sine-wave test tracks to each loudspeaker. The lower tweeter seems to cut at approx. 1250Hz IIRC so no point playing tracks above that (however, it could be useful to identify any potential inequality in these tweeters with 1250 - 10000Hz inputs). I would ensure you have quite a few tracks from 80 to 1250Hz to capture the lower bass to upper bass cross-overs. It is very distinct.
When diagnosing my fault, the B&O technician simply swapped the two ALT heads over and we replayed the test tracks. It was very quickly clear that the tweeter units was a fault and not signal/DSP/Amplification etc of a particular unit....I would imagine swapping the upper bass drivers over on your BL5's could diagnose a similar problem; is it the driver or the internals?
If the problem is internals, then I'm sure your B&O servicer engineer will have a procedure to swap over cards one by one. You should only pay for the units consumed as most faulty components are sent back to Sturer for either re-build or simply swapped as part-ex value.
2 cents worth
David Andel
nmook:
The symptoms you describe lead very much to the main chassis as culprit. I had the same faulty behaviour on both speakers with a delay of maybe a bit less than a year. This has happened 5-6 years after the speakers have been bought new. Unfortunately, replacing the main chassis is somewhat expensive and costs around 800 Euros/speaker here – the speakers should be serviced entirely at your place. Having said that, the replaced main chassis are working like a charm since then, the upper woofer never failed again.
HTH,
David
Doonesbury
Landisville, PA, USA
David Andel:
nmook:
HTH,
David
By "main chassis,", do you mean something like the main circuit board that other circuit boards plug into?
Usually, when I see the word "chassis", I think of "frame" which I'm guessing is not what you meant.
D
CB
> You are Here <
CB replied on Mon, Mar 7 2016 5:39 PM
Doonesbury:
Yes, me too.
The badly named chassis is the main circuit board.
And beware, it seems it is most often refurbished (with warranty), not changed for a new (even if the seller say it is "new"...)
Iceman10245
Berlin - Germany Nova Santa Ponsa-Islas Baleares
I had the problem 3 weeks ago. One has changed the whole chassis, has cost 760.00€. Now it functions again.
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, Beosound Core, BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence ,  BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white,   Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x Beo6, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
Carolpa
Stick out tongueThe tittle an interesting paradox
David Andel
Doonesbury:
It’s how they (= B&O) call the main electronics board which is indeed misleading. And it cannot be repaired, only replaced entirely. The replacement part has been ordered from B&O and was new, the PIN remained unchanged. After the board has been switched, the problem just vanished, so no other part was involved.
Rod
Los angeles
Rod replied on Sat, Nov 2 2019 3:09 AM
Hi, I would like to know how much did you send on the tweeters, I just both a second hand Beolab 2 and one of the tweeters is not working, I even swap them between the 2 speakers and yes it is just the tweeter driver.
Thank you!
Rom
BL5, Beosound Core, Cambridge Magic DAC plus, sony hi res player, Beosound 2
Rod
Los angeles
Rod replied on Sat, Nov 2 2019 3:12 AM
Sorry I meant * How Much did you spent on the tweeters?
Thanks and sorry for the typo!
ROM
Mr 10Percent
I assume you are referring to my old posts?
if so, I think it was £180 with the home service. Don’t hold me to that...it was a while back
Rod
Los angeles
Rod replied on Sat, Nov 2 2019 10:48 PM
Thank you!!
Rod
Los angeles
Rod replied on Sat, Nov 2 2019 10:49 PM
Thank you!!
Page 1 of 1 (15 items) | RSS
