Beoplay H8
Answered (Verified) This post has 3 verified answers | 662 Replies | 19 Followers
Emil Jensen
Denmark
Emil Jensen posted on Tue, Jan 6 2015 6:21 PM
Beoplay H8
Beovision Eclipse, Beolab 5, Beolab 17, Beosound 1 Google assist, Beoplay M3, Beoplay H6, Beoplay Earset
leosgonewild
Verified by ellesofia
My H6´s just went on my local selling site :P
riverstyx
SouthWest UK
Verified by k3wt
k3wt:
Would it be possible to use H7 ear pads on the H8?
Hi k3wt,
No, they are not interchangeable, I tried this on a pair in store a while ago.
Kind Regards,
Martin.
Roger
Norway
Answered (Verified) Roger replied on Mon, Feb 1 2016 4:32 PM
Verified by Mirzoni
This just in from Struer:
Bluetooth reception improvements have been implemented in production from serial number:
Gray Hazel: serial number 2524849 (w1542), and
Argilla Bright: serial number 25120775 (w1543).
BeoPlay H8 Black and Natural are per definition OK from start with improved Bluetooth reception.
Anyone that can confirm this? For the rest of us, knowing that the receiver is in the right H8 cup should help a little (put the phone in the front right pocket, not the left one) - but it would be even better if they have actually solved the issue all together from these S/N´s.
Roger
Daniel
Svinarp, Sweden
elephant:
My early June H8s do drop out.
However I still love them.
I now use them both wired and unwired.
I have not worked out why sometimes they drop out and sometimes with seemingly similar activities they are rock steady.
Still their noise reduction (on ear isolation), noise cancelling, and bass make them a great buy - for me.
Thank you for your answer!
Aussie Michael
Melbourne, AU
elephant:
Still their noise reduction (on ear isolation), noise cancelling, and bass make them a great buy - for me. BeoNut since '75
I also use them wired and wireless. Mainly wired as I think it preserves the battery.
They paid for themselves on my trip to Hong Kong and Japan with the noise cancelling on the plane.
What colour did you get?
Konichiwa from Hiroshima
elephant
AU
elephant replied on Mon, Aug 10 2015 11:01 AM
Aussie Michael:
Ditto for the 14 non-stop hours from LAX to MEL ...
If they'd had them in Love Collection livery I would have gone for that ...
Instead a chose a "match" to the H6 ... with idea that in coupled mode we'd look great together Big Smile
BeoNut since '75
Aussie Michael
Melbourne, AU
Agila Bright is very Tokyo zen decor going from my experience on this holiday ;-)
MrRoast
Hello all,
I was thinking about buying some H8s and so have read the threads and heard all about the dropouts some are having. Understandably I was a little apprehensive about parting with £400 with the issue still looming.
With that in mind I went into the dealer today to physically try a pair with my iPhone 6 and I thought I'd share my experience.
Pairing the headphones was a doddle and with the phone on the table the H8 sounded great! However, I had a dropout as soon as I put the phone in my jeans pocket and then repeatedly if I put my hand on or near my phone. When I took the headphones off to show the dealer they played fine so can only summise that when you have the headphones on your head it reduces the signal to the phone enough for a hand to cause the dropouts.
Sadly, as I really want a pair of wireless B&O headphones (that work without me having to hold my phone in my hand), it's made me decide to wait until the next generation to see if the situation is any better.
As I said some folks seem to be having no issues at all so would just advise people to test them out first!
BeoPer
BeoPer replied on Tue, Aug 18 2015 5:35 PM
Just picked up my new pair and it seems like I cannot charge them. Wherever I try I just gets a rapidly flashing red lamp. Left them over night same result. B&O support told me to return them to shop. Anyone had the same issue?
Michael
Sweden
ONLINE
Perhaps try remove the battery for a few minutes and then connect it again. And then the cable to charge. Do you use a charger with high enough capacity? Try another charger otherwise.
Beolab 50, Beolab 20, Beolab 8000 x 2, Beolab 4000 x 2,
BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9i, BeoPlay H6, EarSet 3i,
BeoVision Avant 55, BeoPlay V1-40,
BeoPer
BeoPer replied on Tue, Aug 18 2015 7:07 PM
Thanks, but no different. Tried several iPad/iPhone chargers + three computers.
Michael
Sweden
ONLINE
Strange thing but then they probably are defective in some way. But you'll be happy when you get a working pair :).
Mikael
Denmark
Mikael replied on Wed, Aug 19 2015 7:29 AM
peryngfalk:
I had a very similar problem.
The first time I charged them everything was working as it should. After the first charge was used up, and I tried to charge them up again the problems started.
I had the same red flashing as you describe. But I also had a sequence where it flashed orange as it should for about 3-5 flashes, but was interrupted by 3 red flashes. That sequence just repeated itself.
I tried different chargers. IPhone, iPad, 3. party, my car. As far as I could tell it acted differently based on the power output. I never got it to work though.
All of this happened during a holiday abroad, so I couldn't really do anything about it. When I came home I tried plugging it in again, and apparently it started charging as intended. But I didn't was a faulty device, so I got a replacement by my local dealer.
Beoplay V1 with Beo4, Beolab 14.4 and ATV4/Chromecast.
Beoplay A2, A9mki (w/ Chromecast Audio), H2, H3, H8.
Millemissen
Flensborg, Denmark
leosgonewild
On our four-hour flight to Spain, I had to reconnect to the H8's five times, and my girlfriend had to reconnect to the H8's three times. The Bluetooth-connection simply disappears, and the H8's has to be manually chosen within Bluetooth setting in our iPhones.
Michael
Sweden
ONLINE
leosgonewild:
Happens daily for me. I'm replacing mine when I have time (which I rarely do).
leosgonewild
Just feels so wrong coming in with three units to complain about (2xH8+1 A2) Surprise
elephant
AU
Michael:
Usually only happens at the start of a session so I am learning to live with it.
Using H8s wired in to the airline's system was 14 hours of uninterrupted bliss for me.
BeoNut since '75
Page 19 of 45 (663 items) « First ... < Previous 17 18 19 20 21 Next > ... Last » | RSS
