Beocord 7000 belt replacement tutorial
Not Answered This post has 0 verified answers | 26 Replies | 2 Followers
Weebyx
Denmark
Weebyx posted on Wed, Dec 31 2014 2:21 PM
Hi and a Happy New Year to all :)
My latest project is getting my Beocord 7000 back to life.
Dillen (Martin) is the supplier of a new belt set, fast and quick delivery, so if you need belts for your Beocord, just ask Dillen in a PM, he will hook you up :)
Even though Dillen supplies a very good description on how to change the belts, I have decided to take some pictures and share them with you..
This tutorial is for the latest version of the BC7000 tape deck with 3 belts, there are also a version with only 1 belt. I guess the BC 6500 might be similar, but i really don't know.
Step 1:
Loosen the 2 screws on the back on the Beocord, but don't remove them, just loosen and then press them upwards and tighten at the top.
Step 2:
I forgot to take pictures of the button panel removal, but it is fastened to the left and right, and just above the tape deck.
Rremove the lid by pressing it slightly back, aprox 1 cm, end lift it up, then remove the red holders for the circuit board, be very careful, the plastic is old and not very flexible any more, so don't use to much force.
Step 3:
Remove the 2 screws to the left and right of the front panel, and tilt it forward, just enough to release the holders for the circuit board.
Step 4:
Remove the connector for the tape deck, and lift up the circuit board, I decided to just loosen both of the metal holders and remove the circuit board completely, but it is not necessary. Then remove the 3 screws that holds the tape deck, and remove the connector to the bottom print. Then take the deck out.
Step 5:
I forgot to take pictures on how to remove the black plastic from the tapedeck, but it is just 4 screws holding it.
The 2 small belts can then be removed (my pictures shows the new fitted).
Step 6:
To get to the big flat belt, the metal housing holding the brass wheel, needs to be removed, on each side of the deck, there are screws holding this bracket, one side has 2 screws that also holds the speed-sensor, remove these 3 screws, and with the use of a small flathead screwdriver, it is possible to "click" the bracket loose and remove it. Notice that the belt is running along the white wheel attached to the brass wheel (my picture is the new belt).
Step 7:
Even though it should be possible to fit the new belt without removing the print, I decided to remove it for better access.. It is easy.. Just unsolder the 2 connectors to the left and right on the print, and press the plastic holder to the left, and lift the board up. This is the old belt.
Step 8:
Fit the new belt and make sure it runs fine along the black wheel.. Remember that when you re-attach the metal bracket, you need to get the belt around the white wheel also, It can be tricky, but I used a "thick" metal stick to stretch the belt around the white wheel just before the bracket was clicked into place.. Just don't use pliers or pointy/sharp thingies, as you might damage your new belt.
Step 9:
Put it all back together and find a tape and try it out... It works :)
Hope this will help others :)
/Weebyx
chartz
Burgundy, France
chartz replied on Wed, Dec 31 2014 2:39 PM
Thanks for that, tremendous work that is!
You are now part of the gang, big time Smile
Jacques
Leslie
the Netherlands City
Silver Member
Leslie replied on Wed, Dec 31 2014 2:42 PM
Great job Jacob, that's the way, less talk and lots of pictures...
By the way, I miss a picture between step 8 and 9, a 3rd hand was needed right? :-)
Brengen & Ophalen
Weebyx
Denmark
Weebyx replied on Wed, Dec 31 2014 2:50 PM
Leslie:
I did it on my own, with 2 hands only :)
I suspect you are missing the way to get the belt around the white wheel ? It can be done, and I have just edited the text for step 6 with how to do this, the last picture in step 6 shows the amount of "open" the metal bracket can be, to be able to "pull" the belt around the white wheel.
/Weebyx
Leslie
Silver Member
Leslie replied on Wed, Dec 31 2014 2:59 PM
Still a great thread. Did this excercise many time but I don't think you can't replace this belt without removing the pcb first. Same excercise for the glassdoor systems like Ouverture etc.
Brengen & Ophalen
Weebyx
Denmark
Weebyx replied on Wed, Dec 31 2014 3:14 PM
Leslie:
It should be possible to get the flat belt in between the PCB and the black wheel, but in the service manual it is also mentioned to remove the PCB, it is much much easier, and you are sure it runs and fits perfectly, and is not damaged by the soldering's at the bottom of the PCB..
/Weebyx
tournedos
Finland
Thanks Weebyx, very nice post that should be useful to many people. 6500 is very similar - I believe only the latest 7000 'cords have the (simplified?) one belt version of the mechanism.
--mika
Weebyx
Denmark
tournedos:
According to the Service Manual I have(and also information from Dillen), the "Tape Deck Version 2" is the one with 3 belts instead of 1.. ?
/Weebyx
MrRoast
@Weebyx
Thank you for this very helpful and informative post! Just followed it to replace the belts in my Beocord.
Yes - thumbs up
Philip1966
Thank you VERY MUCH.
Without this tutorial I would have NEVER done it.
So easy.
Now my Beocord 7000 is back to life.
Regards
Perl
Perl replied on Fri, May 12 2017 9:08 PM
Hej. Har fulgt din fine tutorial, men sidder med et bælte der er for stort. Bestilte hjem til en 3300, selvom det er en 3500. Ved du om der er forskel på de to typer bælter? Mvh
Dillen
Copenhagen / Denmark
Dillen replied on Sat, May 13 2017 7:33 AM
Beocord 3300 og 3500 er vidt forskellige. Og det er remmene også.
Hvorfor i alverden bestilte du ikke til den rigtige model???
Nå, men jeg har korrekte remme til dem begge. Send mig en email.
Perl
Perl replied on Sat, May 13 2017 12:09 PM
Godt spørgsmål :-)
Men når jeg søgte hos Thakken.de havde vist ikke til 3500, så jeg har nok læst forkert :-(
Gary Nelson
United Kingdom
Silver Member
Weebyx,
can I add my word of thanks as well?
Without your tutorial I think that it would have been too much for a mere amateur like me to contemplate.
New belts on the Beogram 7000 means that with Beoworld's help I now have my BS7000 up and running again, such joy.
great stuff
Gary
bvalat
bvalat replied on Sat, Jan 26 2019 12:29 PM
Hope you still read/follow this post.
I registered to thank you.
Without your tutorial, i won't be able to fix my beocord 7000.
I didn't unsolder pcb and put back the white pulley was tricky but other than that your instructions where straight forward.
Page 1 of 2 (27 items) 1 2 Next > | RSS
