Beogram 400x projects
This post has 692 Replies | 4 Followers
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
What solvent did you use to get these pieces seperated?
sonavor
Texas, United States
Posts 3,718
ONLINE
sonavor replied on Tue, Mar 9 2021 3:49 PM
leosgonewild:
Which pieces are you referring to?  Your post does not quote another thread post so I can't tell what the question is in reference to.
-sonavor
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
Lets try again. I``ve been a forum member long enough to knwo how to do this :P
What solevent did you use to separate these pieces?
And what di you use to glue them back together?
sonavor
Posts 3,718
ONLINE
sonavor replied on Tue, Mar 9 2021 4:40 PM
Hi Leo,
I am still not understanding which specific pieces your are asking about separating and gluing back together.
I would guess you are either referring to the wood trim pieces around the metal frame or the metal trim piece on the dust cover.
In both cases the original glue appears to be contact cement. The current way we remove the old pieces is by wrapping the pieces in foil and placing them in an oven to loosen the glue. Rudy describes the process here - "This is best done by baking the plinth wrapped in aluminum foil for an hour at the 'warm' setting (~80-90C) in a kitchen range" and here - "...apply a new aluminum trim".
For both the aluminum dust cover trim and the plinth wood trim contact cement was used.
-sonavor
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
The quoteing obviously doesnt work from my ipad.
I am referring to the acrylic that holds the metal plate in place oin the control panel.
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
sonavor
Posts 3,718
ONLINE
sonavor replied on Tue, Mar 9 2021 7:51 PM
leosgonewild:
Ah, okay.  You are referring to this Beogram 4002 Type 5503 of mine.
The removal technique for that was old age. The keypad parts had fallen apart and that is how I received them.
But it does show that the original glue can probably be loosened/softened for removal.  I would use the same technique Rudy uses to soften the glue on the metal trim on the Beogram 400x dust cover...wrapped in aluminum foil for an hour at the 'warm' setting (~80-90C) in a kitchen range.
I have done a number of resurfacing of the keypad key area (with a matte clear-coat finish) though and I don't remove the acrylic plate.
I remove the old, original clear-coat with some solvent then clean it of all debris before spraying on the new finish.
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
sonavor
Posts 3,718
ONLINE
sonavor replied on Thu, Mar 18 2021 2:14 PM
Very nice work Leo.  You are a woodworking craftsman :-)
-sonavor
matador43
Posts 1,362
matador43 replied on Thu, Mar 18 2021 7:07 PM
Hi Leo,
Very beautifull work. If I wasn't into white beothings, I would follow you right now.
The just in case, woud you mind share litlle bits of your process ?
(I like the standalone beogram flaoting alone, reminds me the 4002c on his marble block, Woud like to do the same but its difficult to integrate in my living room.)
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Absolutely OUTSTANDING.
The talents exhibited by this forum's members are truly impressive.
mr_anders_son
sweden
Posts 1,707
Is this drive pulley in metal still available??
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Page 18 of 18 (693 items) « First ... < Previous 14 15 16 17 18 | RSS
