Beolab 3500 - 1994
Answered (Verified) This post has 1 verified answer | 7 Replies | 1 Follower
Stig Nilsson
Viborg, Denmark
Silver Member
Stig Nilsson posted on Thu, Dec 25 2014 5:25 PM
Hi all
I have a malfunction in my BL3500.
The speaker does not espond to signals from my Beo4 (option Link room)
the timer and mute function works fine directly on the speaker.
My frind will try to trouble shoot the IR pcb but we have no diagram - do you?
Let me know if anybody can help?
Thanks in advance
Hiort
Sweden
Answered (Verified) Hiort replied on Tue, Apr 7 2015 12:41 PM
Verified by Fink
I think I have a similar problem.
My Beolab 3500 suddenly have problems receiving commands from my remote.
I have ruled out the remote as source of the problem, since it works well with my other equipment.
If I try to press the volume control on the remote many many times very close to the BL3500, I may get the volume to move one step or two.
Was it an easy task to fix this problem?
/C
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2  Library: A6, Beocom 6000 Bedroom: M5, Essence remote  Travel: Beoplay E8 2.0, Beoplay P2, Beoplay Earset
valve1
The south of France and occasionally Dublin Ireland
valve1 replied on Fri, Dec 26 2014 9:56 AM
Try turning the power off for a while then try it again is always worth a try first.
Stig Nilsson
Viborg, Denmark
Silver Member
Yah - This advice have in many situations helped me out - But in this case not.
Thanks anyway
Beobuddy
Utrecht, The Netherlands
Beobuddy replied on Fri, Dec 26 2014 12:46 PM
Common fault. Remove display and parts fitted in the plastc holder. Remove holder and clean pcb and Repair probably some broken traces.
Stig Nilsson
Viborg, Denmark
Silver Member
Thanks Beobuddy
I do have a friend in "backoffice" WHO knows his electronics - I will ask him, to follow your advice.
Thanks in advice
Hiort
Sweden
Verified by Fink
/C
Hiort
Sweden
Hiort replied on Fri, Apr 10 2015 2:13 PM
Hiort:
/C
Anyone?
Is it possible to fix problem with the IR receiver as a "do it your selves" exercise?
Andreas Geier
Berlin
Suggested by Andreas Geier
if yet aktuell. I ca repair the IR funktion for IR Dimmer, Beolab 3500 and 9000
Page 1 of 1 (8 items) | RSS
