Beocom 2 charger repair
Not Answered This post has 0 verified answers | 9 Replies | 2 Followers
Patrick vdf van der Heijden
Frl. NL
Patrick vdf van der Heijden posted on Mon, Nov 3 2014 8:56 PM
Hi all,
Does anyone have an idea how to open the base (charger) station of a beocom 2? Thought the battery was done for, so replaced it with a new set, but still it isn't charging, cleaned the contacts on both phone and charger to no avail and checked the voltage and current the base gives... 0, nothing, none what so ever, so guess I have to figure a way out to open the charger base... any takers? thanks.
Reinhard Paul
Wiesbaden, Germany
Hi Patrick,
did you figure out of how to open the table charger? I have the same problem, just opened a threat for this issue
Regrads, Reinhard Paul
Reinhard Paul
BV11, BL8000, BL6000, BL11, Ouverture, BS5/BM5, Beocom 2
Pat
Pat replied on Thu, Aug 30 2018 12:42 PM
Special tool to do it. Check PSU and the cable first, then try to open it.
leosgonewild
Helsinki, Finland
Silver Member
Check the current from the power supply before opening the base.
Reinhard Paul
Wiesbaden, Germany
The plastic from the cover slowly softens and is very sticky. Awful to look at and
impossible to touch. Technically the cgarger works fine.
What special tool do I need? I shortly try a nutcracker :-)
Reinhard
Reinhard Paul
Pat
Pat replied on Thu, Aug 30 2018 11:40 PM
You can use 3 small flat screwdrivers, stick them to the bottom holes ( underneath the label ) and slowly try to pull the bottom plate off.
Reinhard Paul
Wiesbaden, Germany
The three screwdrivers did the job! Thank you for this helpful suggestion.
After having the baseplate off, the rest of the charger is easy to dismantle. You need 2 torn screwdrivers to get the heavy metal plate and the small base with the magnet and the DC pins out of the cover.
Reinhard
Reinhard Paul
Hiort
Sweden
Hiort replied on Mon, Sep 3 2018 8:06 AM
Reinhard Paul:
Reinhard
What will you use instead of the sticky cover that you have removed?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2  Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote  Travel: Beoplay E8 2.0, Beoplay P2, Beoplay Earset
Reinhard Paul
Wiesbaden, Germany
I used the original part from B&O. My local dealer ordered it for me. The electronics and all other parts fit smoothly only into the original cover.
Reinhard Paul
dcarrete
Hi! My charger is also falling apart. Did you fix your? I think the material of the charger had only a 15 year life? Any replacement possible? Also the joystick fall apart, when I was trying to sell it!
Page 1 of 1 (10 items) | RSS
