Advise on NL/ML network needed
Answered (Verified) This post has 1 verified answer | 29 Replies | 2 Followers
Hiort
Sweden
Hiort posted on Thu, Sep 18 2014 4:27 PM
I'm swapping my BV10-40 for a BV11-46 and thereby need to join my exiting ML network with NL.
I have discussed with my dealer but I would like the Forums advise as well.
This is my planned setup:
New stuff I plan to add, apart from the BV11:
- Beolink Wireless. That bit is cabled today but it does not look so good.
- NL/ML converter. Obviously needed and part of the deal I´ve done for the BV11.
- Delay box. I will play music on the BL2000 and the BC2 simultaneous, and the delay box will fix that as I understand it.
Some questions:
  1. Is it okay to build a network after a Beolink Wireless, or are they intended to use just to connect directly to e.g. a BL3500?
  2. Can the delay box be "tuned" or is it a fixed delay?
  3. Is someone using powerline adaptors between the BV11 and a router when using NL/ML converter. Does it work well?
Any experience out there that I need to know, or general advise would be awesome.
Millemissen
Flensborg, Denmark
Verified by Amazone
That is so!
you can also connect an ir-eye and speakers to the converter - and use it as an 'Active Link'.
Nice to know before you decide where to put it.
Hiort
Sweden
Hiort replied on Fri, Sep 19 2014 3:27 PM
Millemissen:
Confused
Could someone please tell me how to upload two pictures in the same posting???
Greetings MM
Thanks for input MM.
Easiest way is to upload photos to "your files" here at the site.
Then simply select them one after the other by clicking at the  "insert media" button and select them.
Hiort
Sweden
Hiort replied on Fri, Sep 19 2014 9:55 PM
One more advise needed.
Where shall I best connect my Playmaker? Today it is connected to teh BC2 using RCA connectors to the analog input.
I know there is RCA-in on the NL/ML converter. Is that a better place to put it, of some reason, or does it not matter?
elephant
AU
Millemissen:
Confused
Greetings MM
Upload them to your image library first - or use an image service like FLICKR
then use the movie strip icon to point urls to either FLICKR or your Beoworld image library
BeoNut since '75
stijndc
Mechelen - Belgium
In my setup, I have linked my AirPortexpress also to my NL/ML convertor. Works like a charm.
Big advantage is that you can setup up your convertor to a source. Before my AE was linked with BS4 I had to use A.Aux button. Now I set it the convertor up with V.Mem, which is easier accesible on the beo4.
Hiort
Sweden
Hiort replied on Sat, Sep 20 2014 2:11 PM
stijndc:
Thanks!Smile
I was not aware of that. So I can then connect my Playmaker to the converter and, as you, use v.mem instead of a.aux.
Millemissen
Flensborg, Denmark
Verified by Amazone
That is so!
elephant
AU
Millemissen:
Here is an 'official' example of a setup including the (NL/ML) Delay Box - and the Network Link router.
Hi MM
the jpegs are useful, however I see you have a PDF.
I can't find that PDF via google.
Are you able to make the PDF itself available?
BeoNut since '75
Millemissen
Flensborg, Denmark
Just curious - what would be the difference?
elephant
AU
Millemissen:
The clarity of the text in the diagrams !
eg ......
BeoNut since '75
Millemissen
Flensborg, Denmark
Hi elephanth,
maybe it's because I am dumb - or too impatient, but....
...this is what I get, when trying to upload the .pdf file to my files:
"Only files with the following extensions are allowed: zip, gif, jpg, jpeg, png, bmp, txt, xml."
Anyway - I think you get the message from the screenshots - and that was the important thing.
hfat
Vienna, Austria
hfat replied on Sun, Sep 21 2014 12:11 PM
Millemissen:
Hi elephanth,
You could zip the pdf file before uploading it
hfat
tournedos
Finland
Millemissen:
I believe you should be able to attach any file type from the Options tab while composing (which I find much easier for a single attachment anyway).
--mika
Millemissen
Flensborg, Denmark
I'll try that, when I am at my Mac again - which is not very often nowadays.
Millemissen
Flensborg, Denmark
Well - that was easy Smile
elephant
AU
Thank you for ...
3540852A NL_ML Delay Box.pdf
... that's much better !
BeoNut since '75
Page 2 of 2 (30 items) < Previous 1 2 | RSS
