The new Beoplay S8... Not sure what to say.
Answered (Not Verified) This post has 0 verified answers | 140 Replies | 4 Followers
Rob - Danish AV
Melbourne
Rob - Danish AV posted on Thu, Aug 21 2014 9:36 AM
So I have just seen on Facebook via the Beoplay page.. The new S8 speaker system...
it it looks like a Beolab 14 with 2 speakers and a sub!
http://www.beoplay.com/products/beoplays8
i'll let everyone give their thoughts on this but I don't really know what to say about it!
PhilLondon
London
http://www.freshnessmag.com/2014/08/21/bang-olufsen-beoplay-s8-wireless-speaker-system/
Funny how they call it a wireless system... Maybe because there are no cables on any of the pictures!
Beoworld app with direct photo upload and emoticons. Other apps: ConsltThe Story Mouse
Millemissen
Flensborg, Denmark
B&O write: "take your streaming experiences to the next level".
Nowadays all journalists seem to have nothing but 'streaming' in their heads.
No wonder they get a set of active speakers mixed up with the streaming devices that float the tech-world today.
rob08
rob08 replied on Sat, Aug 23 2014 6:14 PM
elephant:
Australian price AUD 1,799.00
Can anyone confirm ?
And no price change on his bigger brother ... so far ? The Essence of B&O is discretion in design and life
On the Beoplay webbisar the price is 10990 SEK.
Heard from my dealer that the Beolab 14 2.1 is end of life and the 4.1 and 5.1 will get a 20% discount
Aussie Michael
Melbourne, AU
I don't get it, how can you use this in addition to your 3.0 system and use the S8 as rears?
I saw on the manual it looks like you could ideally set it up to be more than 2.1 if you had more speakers?
Regards
Millemissen
Flensborg, Denmark
As long as the S8 has seperate PL-in's for the sub and the satelites, it doesn't matter to the satelites whether they are fronts or surround speakers.
It is just a matter of configuring the PL-port in the Avant - to which they are connected.
And you would have to place them in the back of your room - of course Stick out tongue
With the configuration of the internal speakers as front-left/center/front-right you would then have a 5.1 system.
Yendys
Sydney
Yendys replied on Mon, Aug 25 2014 11:28 AM
Millemissen:
If this is actually the case I'll be placing an order for the S8 and moving my BL2 to another room along with my existing surrounds
Millemissen
Flensborg, Denmark
Might be a good idea.
But I am not sure it would be an upgrade - depending on what you use now as surround speakers....
....and what you are expecting from your 5.1 system.
Hiort
Sweden
Hiort replied on Mon, Aug 25 2014 12:22 PM
Millemissen:
My dealer tells me there are no PL - in on the S8, only RCA.
Anyone that can confirm this?
Millemissen
Flensborg, Denmark
Please refer to the user guide (pic posted on the first page of this theead) - that is what I do!
Your dealer should take a closer look too.
Aussie Michael
Melbourne, AU
On the tech specs on the beoplay website, it says
Input
Line in (3.5mm Jack / RCA plugs)
Power Link
Output
2 x speakers
In the Box
So its got PL
1 Subwoofer with cover, 2 Satellites with covers, Mains cable, RJ45 - RCA cable, RCA - 3.5mm Jack cable, 2 speaker cables, 2 table stands, 2 wall brackets, Quick guide
Hiort
Sweden
Hiort replied on Mon, Aug 25 2014 2:29 PM
Aussie Michael:
Input
Power Link
Output
2 x speakers
In the Box
So its got PL
Alright,
Dealer mentioned he had B&O prod responsible in the store the other day, and he said there was no PL.
Must be a misunderstanding.  After looking for specification himself he now confirm that PL indeed is there. Would be very odd othervise.
Case closed
 Subwoofer
 Satellite
DESIGNER
David Lewis Designers
LOUDSPEAKER SYSTEM
Subwoofer
One-way
MATERIAL(S)
Cabinet: Composite materials
Cabinet: Aluminium  and steel
COLOUR(S)
Black
Cabinet: Black/Black
Cover: Black
POWER CONSUMPTION
30W
OPERATING CONDITIONS
10-40° C, 50-104° F
10-40° C, 50-104° F
IMPEDANCE
4 ohm
8 ohm
POWER AMPLIFIER, BASS
280W into 4 ohm
POWER AMPLIFIER, MIDRANGE
140W into 8 ohm
EFFECTIVE FREQUENCY RANGE*
26 - 20,000 Hz
CROSSOVER FREQUENCY
120 Hz
SENSITIVITY**
88 dB SPL re 125 mVrms re 1m
BASS CAPABILITY
100 dB @ 10% distortion @ 50Hz
CABINET PRINCIPLE
Bass reflex
Sealed box
CABINET VOLUME
15 litre
0.5 litre
BASS DRIVER
1 x 8"
MIDRANGE DRIVER
1 x 2.5"
FEATURE(S)
Adaptive Bass Linearisation (ABL)
Thermal protection
Line sense - auto on/off
Thermal protection, via power estimation in Digital Sound Engine
CONNECTION(S)
Input:
2 x Power Link incl. 3 x Line by Power Link
1 x A/V multi connector
Output:
2 x speaker
1 x speaker
ACCESSORIES
2 x 6 m speaker cable (white)
Mini jack to RCA line adapter
RCA to RJ45 line adapter
Wall bracket (included)
Table stand, low (included)
Cover Black (included)
ROOM ADAPTATION
Variable
kimchr
kimchr replied on Mon, Aug 25 2014 5:33 PM
Millemissen:
Hi Millemissen
I think it is still very important to add to you point that if you have an Avant or Any Beosystem 4 based TV it does not matter if the S8 has one or two powerlinks. The Audio engine will route the low end from all channels to the most capable speakers in your setup. That will for sure be your S8 when used in combo with the Avant 3.0 speakers.
This fact is so important, it absolutely underlines the wonderful features of the audio engine and makes the S8 an incredible bargain as an upgrade to a stand-alone Avant.
/Kim
Millemissen
Flensborg, Denmark
Hi kimchr,
never doubted that function - in fact I never mentioned it, because it is obvious.
But if you have a LFE channel (the .1) from a Bluray/DVD or alike, you should really configure the port as a dedicated sub.
The important thing - by the BSys4-based engine - is that you can configure all ports just like you need them, and in case of the S8 use the satelites as surround speakers.
N.B. This configuration only make sense with the Avant, because the Avant has a center channel built in in addition to the right/left speakers.
Of course you could configure the built-in speakers as a center and add external fronts for 'better sound' - if you want/need that.
And of course you can use the S8 with any 5.1 enabled BV.
But my main point was, that you - with the help of the S8 - can create a 5.1 system with the Avant in a cheap and easy way. A system that would be sufficient for a lot of people.
Aussie Michael
Melbourne, AU
Millemissen:
Hi kimchr,
Actually, I didn't know this , so thank you Kimchr, sometimes stating the obvious helps dummies like me
*bleep bleep*
Millemissen
Flensborg, Denmark
Sorry Michael - I should have added: .... If you have done some research on how the new audio engine works.
See also:
http://www.tonmeister.ca/wordpress/2013/12/13/bo-tech-what-are-subwoofers-really-for/
And - of course - The Technical Sound Guide here:
http://www.bang-olufsen.com/da/customer-service/product-support/picture/beovision-11
Page 4 of 10 (141 items) « First ... < Previous 2 3 4 5 6 Next > ... Last » | RSS
