My dealer installed PUC software for the Humax Fox T2 and Foxsat HDR on my BV8 but did not give me a printed guide to the commands. I have worked out most of them by trial and error but not all. Can these guides be downloaded? The dealer says he can't help because he has now finished with B&O and has "no access to the system".
Thanks for any help,
David.
This dealer facebook page seems to have come to your aid;
http://tinyurl.com/qcdynrc
http://tinyurl.com/mjcsvzg
The most common should be showed, when you press 'Menu'.
StUrrock: This dealer facebook page seems to have come to your aid; http://tinyurl.com/qcdynrc http://tinyurl.com/mjcsvzg
This is exactly what I need and should have been supplied by the dealer. Many thanks for the links!
David
Millemissen: The most common should be showed, when you press 'Menu'. MM
Yes indeed they are but the "stop" and other commands were evading me. All is clear now.
Thanks, David
