NON B&O speakers and Beomaster 6500
Not Answered This post has 0 verified answers | 4 Replies | 0 Followers
foe
foe posted on Mon, Jun 30 2014 10:28 PM
Sorry if that was raised here before. I've got a Beomaster 6500 Amp and I'm not sure if it amplifies :) although it works when I connect external cd player and listen through the headphones.  Now, how can I connect my Ruark speakers (speaker banana plugs) to B6500 with 2 pin-din speakers sockets? I just can not find a proper ready-made cable on ebay or an adaptor (2 pin-din to banana). Any other way to check whether my amp works properly?
Steffen
Denmark
Steffen replied on Mon, Jun 30 2014 11:06 PM
I don't know if there is a 2 pin DIN to Banana adaptor.
Have you thought about making your own cables? Just buy a set of male DIN speaker plugs - (there are lots of sites on the net, where you can find them) - and mount them on the speaker-cables.
Cooker
Cooker replied on Tue, Jul 1 2014 12:10 AM
Ask Steve at Sounds Heavenly, I'm sure he has or can make something for you.
Top bloke.
foe
foe replied on Tue, Jul 1 2014 1:32 AM
Thanks for replies. I'm about to buy http://www.ebay.co.uk/itm/151254024861?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 - then will just attach those banana plugs and voila. I just didn't know it's that easy to prepare a speaker cable.
Steffen
Denmark
foe:
Yes - It can be as simple as that ;-)
Page 1 of 1 (5 items) | RSS
