Dolby 7.1 on BV 7
Answered (Verified) This post has 1 verified answer | 5 Replies | 2 Followers
mafanni
mafanni posted on Wed, Jun 25 2014 9:42 PM
I am lost. Just bought a nice used pair of BL3 to add to my BV 7-40 MK3 with BluRay Kit. System has now 2x BL1, 1x BL2, and 4x BL3. I configured the 4 BL3 as 2x surround and as 2x rear speaker.
Than I flipped in a nice BluRay disk on the tray, selected sound-option 7.1 in the BluRay menu. and hoped for 7.1 surround sound output.
Checking the speakers, the two rear BL3's switched on but do not produce any sound. Than I display in the TV menu the sound-system. It says input sound = 5.1 and output sound = 5.1. So I guess that has something to do with software or with settings.
Can anyone help with setting ideas to get the nice and sweet 7.1 surround-sound out of my system?
Thanks to all of you
BV 7-40:
Type no.: 9376 with retro fitted genus B&O internal BluRay kit
SW of BeoVision 7-40:
AP SW8.12a
IOP SW 23.00a
Millemissen
Flensborg, Denmark
Verified by mafanni
@Räuber - that might be the 'problem'.
@Symnes - where do you read these specs?
@mafanni - could you post a screenshot of your speakers-setup (from the menu of the BV7-40 MK3), please?
Can you access the menu of the built-in BRP? How does the menu look - screenshot if possble?
As far as I remember two different BRP were used in the BV7.
Millemissen
Flensborg, Denmark
Hi mafanni,
the surround decoder in the BV7 can not handle the 7.1 signal (which is either a DTS-HD Master Audio or a Dolby TrueHD signal) on the BR disc - which one did you choose?
I can't say if the built-in BRP is able to decode those sound formats to a PCM signal (which the BV can handle). Very little information about this can be found.
If a Dolby TrueHD signal was choosen the BV probably has picked the core signal (from within the HD signal), which is a lossy Dolby 5.1 format.
Not a complete answer - but maybe it helps a bit.
Raeuber
Germany
Raeuber replied on Wed, Jun 25 2014 11:26 PM
Hi mafanni,
the Bluray player of my BV 7-40 Mk 6 is able to provide audio format 7.1 if available on Bluray. The audio menu of BV 7 shows 'input audio format = PCM 7.1' ('output audio format is 5.1 because I have only 5 speakers and a sub connected to my BV 7). But I don't know if this is the same with Mk 3).
Regards
Räuber
symmes
Answered (Not Verified) symmes replied on Thu, Jun 26 2014 1:30 AM
Suggested by steve1977
Raeuber:
Hi mafanni,
Regards
Räuber
According to the spec sheet, MK 3 will play 7.1, I assume in PCM.
Millemissen
Flensborg, Denmark
Verified by mafanni
mafanni
mafanni replied on Thu, Jun 26 2014 10:27 PM
Hi Millemissen,
can't manage to upload pictures. The BL3 are connected as surround speaker left and right and as rear left and right. The speakers respond if i am accessing the speaker distance menu with the expected noise signal as all other speakers do there as well
nice regards
mafanni.
Page 1 of 1 (6 items) | RSS
