Timer on old beomasters
Not Answered This post has 0 verified answers | 7 Replies | 1 Follower
erandlux
erandlux posted on Tue, Jun 17 2014 8:02 AM
Hello guys,
Do you know wich model of older beomaster like a bm 7000 or older have a timer facility like the one on an ouverture, a different wakeup time for each day of the week ?
Thanks for your answers
Eric
waterlander2004
The Hague, Netherlands
erandlux:
Hello guys,
Eric
I believe the BM5500, 6500 and 7000 all have that functionality and can be easily programmed via their Master Control Panel.
Guy
Buckinghamshire
Guy replied on Tue, Jun 17 2014 8:42 AM
The BeoCenter 9500 can also be programmed in this way but only with a two way remote like the Beolink 5000 or 7000.
RaMaBo
near Munich
RaMaBo replied on Tue, Jun 17 2014 8:54 AM
Hi Eric
the Beomaster 5000,5500, 6500 and 7000 have a timer faclity as well as the Beosound 2500 which is the early Ouverture.also the older BeoMaster 6000 an 800 have a limited timer facility..
Ralph-Marcus
Dillen
Copenhagen / Denmark
Dillen replied on Tue, Jun 17 2014 12:04 PM
Beomaster 8000 has no clock and therefore no timer functions.
Beomaster 6000 has a timer function but it can't be set to a different time each day.
tournedos
Finland
Also, Beomaster 5000 & 5500 do not have a separate timekeeping IC, so they will lose the time & date if mains power is interrupted. Timers themselves will be preserved (the memory IC has a backup battery), but they're not going to wake you up at the expected time if you had a power break...
6500 & 7000 will keep all settings over a power break, but the MCP cannot set very complicated timers, you will need a BL7000.
--mika
erandlux
erandlux replied on Tue, Jun 17 2014 12:57 PM
Thanks for all your replies.
I have a BM7000'sleeping on a shelf, I will try to configure the timer. It will replace my ouverture.
Just need to find a beolink 7000 or 5000 to configure the timer on a daily basis, ....... And a pair of beovox ( I always wanted a pair of CX100, maybee it's time to go for it)
Anders Jørgensen
Denmark
I can ad to the 6000 and 8000 that a suiting Beocord do have timer options for playback and recording
Page 1 of 1 (8 items) | RSS
