Beogram 5500 and a Beosystem 2300
Not Answered This post has 0 verified answers | 22 Replies | 1 Follower
onnnnn
onnnnn posted on Wed, May 2 2012 1:00 AM
So, here I am again asking basic types of questions.
I am using a Beosystem 2300 with a set of Beolab 2500 speakers- I have a Beogram 5500 turntable and pluged it into the same AUX where I have plugged my ipod cable adapter--I am not hearing the records--What am I missing other than you ight not be able to use a turntable with the 2300 which I would find unlikely.
Thanks,
Jonathan
Søren Mexico
Mexico City
ONLINE
To play from a Beogram you will need a preamplifier, some newer Beograms has the preamp build in, but you BG 5500 does not, neither does your BS 2300, some older receiver/amps has the preamp build in Smile, yes confusing.
So you will need a preamplifier, I used this one I used this for connecting, BM, Ipod, and TV sound, looks like this
Søren Mexico
Mexico City
ONLINE
And you can connect like this
Søren Mexico
Mexico City
ONLINE
But you will need a cable like this, I know you will now ask, "why 4 RCA connectors", that is for future use, the 2 extra is for line out, you are going to use line in.
onnnnn
i forgot to mention I have the entire beosystem 5500 so I do not need the preamp (yes?) I just did not want to use it all and wanted the clean look of the beogram and 2300 --I have another turntable ( which one?) I will have to find it and post here to see if it does have its own built in amp
Jonathan
joeyboygolf
Ely, Cambridgeshire, UK
onnnnn:
Jonathan
Correct, in this case, the RIAA pre amp is built into the Beomaster 5500.
If you want to use the deck with BS2300 then Soren is quite correct, you will need the stand alone pre amp between the two.
Regards Graham
onnnnn
onnnnn replied on Wed, May 2 2012 11:03 AM
So, I can not use the BS 5500 with the 2300 as the pre amp?
tournedos
Finland
I guess in principle you could use the TAPE2/AUX connection of the Beomaster 5500 to output a line level signal to the 2300 (while the 5500 is playing phono)... but it really gets so complicated with the conflicting remote control issues etc, that I really wouldn't bother.unless to perhaps prove a point.
--mika
onnnnn
onnnnn replied on Wed, May 2 2012 12:15 PM
just want it to work --what gets complicated--could/would you  give a step by step set up to see if it does work?
Thanks,
Jonathan
onnnnn
onnnnn replied on Wed, May 2 2012 12:50 PM
maybe this should be a whole new question but I will post it in this question first
SO I found all 3 of my decks but have no knowledge on any of them except for what I am now learning about the BG 5500
I also have a BG 2400 and a BG 4004
What I would like to know  is
1- which on the 3 is the better turntable?
2-what stylus is needed for each and can I interchange them if I send the numbers to anyone that knows that information?
3-can any of the newly listed  work with the BS 2300 without my buying a new pre amp?
again, Thanks,
Jonathan
Søren Mexico
Mexico City
ONLINE
1. The most popular of the 3 is the 4004, the 2400 is a very good radial tracking turntable and in my opinion underrated.
2. The cartridges for 4004 and 2400 are inter changeable, its the MMC 20 series The 5500 has a MMC 1-5, look here
3. No, you will need a preamp.
As for using BS 5500 as preamp, you connect the line out RCA on the BM 5500 to the aux in on 2300 with the fore mentioned cable, or get a male to male 5 pin din plugs cable and use tape 2 to aux.
But I recommend to get a preamp and use your BG 2400 to begin with, it has the simpler mechanics and is most likely to work without problems, but if the 4004 and the 2400 has been standing for a long time without working, you may need new bands and  some service on both of them.
As for using the BM 5500, no problems, but its a pity to split up this nice and working system,
Its now time to tell what other goodies you have in stock, a list with pics would be interesting Laughing
onnnnn
Soren
Took your recco and ordered the pre amp
I will likely sk you the sequence of adding the turntable and the 2300 ( just not my forte) if that is okay with you
Jonathan
Søren Mexico
Mexico City
ONLINE
onnnnn:
Soren
Jonathan
No problem Jonathan, but get the cable too, now which plugs does your turntables have, DIN or RCA (phonoplugs)
onnnnn
onnnnn replied on Thu, May 3 2012 12:24 AM
not sure which table I am going to use---I have rca cords all over the palce they come with every Direct TV unit I have ever had---the DIN I am not sure of---- ?
I will email you later after dinner
Jonathan
onnnnn
onnnnn replied on Thu, May 3 2012 12:28 AM
Hi
The 2400 and the 5500 decks are 7 pin Din's-- what else do I need to get?
Page 1 of 2 (23 items) 1 2 Next > | RSS
