Since I've posted my redesign of the Redline 60s last year, several people in several countries have used my design and modification and have been very pleased with their results. Below is an email I just received from another Redline owner that used my passive radiator modification and he is experiencing lower and tighter bass now. He only used the design in is Redline 60; not his 60.2.
Cut & Pasted:
[Quote] Mike,
Both sets of speakers are rebuilt and back up and running. They sound fantastic. Although their looks are identical and the drivers are the same the difference in bass reflex designs and two very differently designed crossovers makes the speakers sound completely different from one another.
The 60's with the radiators really deliver the bass better than the 60.2. The 60.2's on the other hand deliver a little better at the higher end.
Either way I am happy and getting the speakers off the floor in my living room just adds the extra touch. The other set which I will use in my other living room I plan to hang from the ceiling.
I have picture of all the work and will set up a Picassa Photo page since I already have an account there in a day or so and send you the link.
Thank You so much again for all your help. As it turns out several new threads have popped up on Beoworld regarding the RL60's and ABR foam rot and general rebuilds. Cooldude and myself both plugged your passive radiator design. [End Quote]
When I posted my design, my results could sound biased. When you read the results from someone else that has also duplicated my design, that affords some credibility. I hope that this can help others with their Redline 60s. I have full pictorial and text instructions on my website to help you.
Thanks guys,
Mike
