OK, this MX4500/5000/3000 has nothing to do with this MX3500/5500 workshop. It's a complete different design, no parts are compatible. This chassis was manufactured by Thomson, called ICC5, also used by Philips - Telefunken and many other companies. Just to make sure, that this information here does not fit to the MX3500/5500. 😉
But try this:
Powersupply: Replace TP24= BU508A or S2000, check for insulation foil.
CP23 2,2nF 2000V (!!!! probably the reason for this defect...!!!)
CP04 100uf 25V
CP19 47uF 16V
CP24 47uF 100V
CP26 470uF25V
DP23 BY399
DP26 BA157
All parts are under the plastic cover. After that, there should be no blown fuse any more.
But... at least exchange some more of the caps. CP37 4700uF, CP32 1000uF and CP46 2200uF are the next to fail...
Very common on this ICC5 is also: TL31 BU508A or S2000, usually with a defect CL48 12nF1600V or CL44 440nF 250V. If there are vertical lines: RL44=56 and RL42=68 are gone...
P.S.: who gave you this part list? It does not fit at all to the ICC5 board...
