I left the aluminium bare as it is. Tried to spray it with clear coating but that became messy and looked unnatural.
The problem is, if you leave the aluminum bare it will not continue to look good...you'll need to 'harden' the surface (as B&O does).
Well -you can not do it as they do in the factory ๐ But -the solution for amateurs is...sodium hydroxide.
I once bought a set of badly damaged alu C 30's with lots of scratches. I sanded the surfaces and afterwards i gave it some "Caustic Soda" dissolved in water (Sodium hydroxide) to harden the surface. It looks very close to the original finish. I think it's better than some clear lacquer.
