Hey Evan,"In any case would you mind doing a photo showing exactly what Chartz is suggesting?...especially the pre-amp section ot the 47k trimmers?
*Oh and thanks for answering my previous questions on the Caps & why the use of the bubble plastic*
Circled in red is the main 5000uF reservoir capacitor. Jacques recommends I change this because of potential failure. The failure of these three main capacitors give a distinct symptom to the sound output of the amplifier, a low 60Hz buzz (AC current).
Circled in green are the trimmers on the main amp board. These are used to fine tune the amplifier and over time corrode, losing sound quality. There is also one in the upper right of the photograph, circled in yellow, on a different board that will be replaced.
Finally here is the preamplifier board, with no less than 6 trimmers. These will be replaced also and for the same reasons.
