Thanks to Chris (Medogsfat) who very kindly helped me to a new output transformer.
Your help is greatly appreciated ! 🤒
With this part, I will hopefully be able to get the output stage working as
it should.
The original transformer was scrutinized but no obvious faults could be seen,
the way too high primary DC resistance however, proved that it was indeed defective.
The new transformer is a brand new general purpose component. It has several
tappings on both primary and secondary and will be easy to fit inside the
speaker cloth bag.
The best suitable tappings were selected and the speaker wires attached accordingly.
The transformer was then fitted using the original mounting holes in the
speaker metal basket.
Power up.
Hmmm... the new transformer didn't provide the significant change in output volume
that I was hoping for.
It did, however, set the voltages around the output valve, particularly the anode
voltage, correct.
