Leslie is very skilled in many ways and I admire most of his work.
I do agree with Chris, though, in that shim'ing is an absolute must when refoam'ing woofers.
Just as important as using the right glue and keeping the workspace clean.
Leslie is either very skilled or just plain lucky - or both.
It's a fact that some people are better cut out for DIY than others.
Leslie may have a good feeling about things, refoaming a.o. From seeing what he has accomplished,
I feel it safe to say, he has and therefore he has a high succes rate but, as Chris have also found out, not
all people have this feeling.
By far.
Some people decide to stop when they find out that their skills aren't adequate and while there is still
a chance of rescuing the driver, others just speed ahead.
The owner of these CX50 never got around to glueing anything.
He removed the old surrounds and it didn't quite work out as in the Youtube video...
Login to view image
I've seen glue "strings" across the cone and down the center.
I've seen cones that had the outer edge where the old foam sat cut off with scissors, leaving nothing for the new surround to sit on. A full MS150 set...
I've seen drivers with torn cones and the likes.
I've seen spiders pulled and stressed completely out of shape.
I've seen surrounds mounted using building silicone - lots of it.
I've seen deformed coil formers from owners forcing the included cardboard shims down a gap that was only about half the width.
I've seen cones with strange wrinkles and cones that were "extended" using paper to reach out and fit a new non-correct diameter surround.
Hot glue melts some types of foam, don't ask how I know.
Everytime a battle to save an extinct B&O driver and everytime I'd wish they'd asked a pro.
It's not expensive to have it done by a pro. About the same price as one of the cheapest and lousiest replacement
drivers that won't have nowhere near suitable T/S parameters anyways.
Even owners who actually tried to shim everything up correctly can face tough luck.
Login to view image
This woofer came from a fellow Beoworlder on the other side of the globe. He had it refoam'ed by a pro but
it "didn't sound quite right".
I took this photo when I found foam remains caught and mashed out between the coil former and
magnet center piece. That sticky stuff is very difficult to remove.
The refoam job itself was perfect, the guy who did it just wasn't aware of a tiny piece of old foam debris.
There are many ways for things to go wrong, even if you try to do it right.
Shim'ing and making sure everything sits correctly, is the least thing you can do.
